Question about Franke Saphira Espresso & Coffee Maker
Hi there, My Franke Saphira reads malfunction 3. My technician are unable to identify the problems.
leethedeuce
  • 4472 Answers
SOURCE: franke saphira bean to cup
How long have you owned the unit? That is very possible that or the control/button for it is bad.
Once I have more information I can assist you further.
Thanks,
Lee
Posted on Sep 22, 2008
SOURCE: Franke safira reads Malfunction 4
error/malfunction 4 usually means thermistor/sensor on steam generator block has failed ie open circuit /disconnected......................small metal encapsulated device clipped or screwed to block,2 wires to harness plug...
Posted on Mar 05, 2009
guybutler86
  • 9 Answers
SOURCE: Franke saphira will not exit rinse unit, will not
The machine has two pumps - one for each boiler. Did the Franke man check both pumps were working. If the main boiler pump has failed, the machine will know that the rinse hasn't occurred and won't go any further.
Posted on Feb 18, 2010
guybutler86
  • 9 Answers
SOURCE: Franke Saphira - fill water tank
There is a magnet fitted in the side of the tank. Lift out the tank and make sure the magnet is free to move. It might be that some water has been spilt onto it and it's crusted up. Failing that, suspect a faulty microswitch inside.
SOURCE: franke saphira malfunction 8 help
We Had The Same Malfunction 8 Problem And It Came Down To A Swolen O-Ring In The Brewing Piston, We Replaced The O-Ring With One Slightly Smaller That Still Sealed The Compartment And Our Problem Was Solved, Hope This Helps Others.
Posted on Feb 19, 2010
Franke flair malfunction 8
you have problems with the brewing group. perhaps the o-ring on the upper piston is broken.
Dec 05, 2012 | Franke Saphira Espresso & Coffee Maker
Franke Saphira malfunktion 2
You might find the answer on our Franke video
More info at Denby Dale Coffee
Nov 21, 2012 | Franke Saphira Espresso & Coffee Maker
Need a parts brake down diagram for a franke saphira coffee machine!!!
The Franke Saphira is the same machine as the Jura X7.
Here is an interactive diagram.
Mar 04, 2011 | Franke Saphira Espresso & Coffee Maker
Hi, Franke Saphira. 'Empty Drip Tray' message doesn't shift when in descale mode - not in any other mode though, only when trying to descale. Any ideas? Cheers
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Sep 29, 2010 | Franke Saphira Espresso & Coffee Maker
Can I use Jura cleaning tablets on franke saphira?
hi , you can use the cleaning tablets as jura and franke have the same brewing unit,
Sep 16, 2010 | Franke Saphira Espresso & Coffee Maker
Hi. Malfunction 4 on Franke Saphire coffie machine, What should i do ?
The temp sensor on the Steam block has failed, a replacement is required
Aug 06, 2010 | Franke Saphira Espresso & Coffee Maker
Franke saphira will not exit rinse unit, will not rinse the coffee head but will supply hot water and steam. but will not depense any coffee. help please. I have had a Franke Man out and he has no clue he...
Feb 16, 2010 | Franke Saphira Espresso & Coffee Maker
Franke saphira malfunction 8 help What is this?
Malfunction 8 is mother board failed, you will have to take it to franke uk
Apr 16, 2009 | Franke Saphira Espresso & Coffee Maker
Feb 24, 2009 | Franke Saphira Espresso & Coffee Maker
Franke Saphira Espresso & Coffee Maker Logo
87 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
frankecoffee
Level 1 Expert
Jay Finke
Jay Finke
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
