Question about Home
Hi I have just purchased a RAK Venice soft close replacement toilet seat and was assured that it would come with fitting instructions. Needless to say it didn't. Could you please advise hoe to remove the old seat and replace with the new one. I am not the best DIY person in the world!! Really appreaciate any helpor advise you could give me. Many Thanks Darren Shaw
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
  • 31 Answers
SOURCE: How do I adjust hinges on a soft close toilet seat
it does this get used to it.
Posted on Apr 11, 2010
Magaiver
  • 707 Answers
SOURCE: soft close toilet seat
There are two plastic tabs that clip up on the back of the seat and tighten not at bottom.Hope this helps.
Posted on Aug 12, 2010
taran_2005
  • 10515 Answers
SOURCE: I want to replace the
Generic procedure for these are :-
1. Remove the old toilet seat and any mounting hardware connected to it. Throw the old seat away as well as any old hardware. You don't want to mix up the new with the old.
2 Using a soft scrub cleanser that will not scratch the porcelain, clean the toilet surface where the old seat was attached. Don't forget to clean the bottom surface where the old hardware was attached.
3 Lift the hinge covers on the new seat before placing it on the toilet. Align the new seat to the mounting holes and insert the two bolts.
4 Thread a nut onto each bolt, making sure that the new seat is in the proper position before tightening.
5 Using the wrench and screwdriver, tighten the nuts making sure not to over-tighten them. Once the hinge covers are closed, the job is complete.
Kohler toilet seats are held on by plastic screws. If you cant get the nut on the bottom to come off then use a sharp chisel and just chop the head of the screw off.
Oh yea the screw head is located under a cap. Stick a screw driver under it and pry up and it will open.
How i done it on similar model - To replace seat. look right at where the lid hinges there is like two block about 6 to 8" apart. take a small screw driver and pop free the little door covering the screw head. take a big Philips or straight head screw driver. and then look under neath where bolt would stick out below. and you will see a nut,you should be able to hold nut by hand as you tighten the bolt. both nut and bolt are plastic. draw good and snug.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 27, 2010
  • 1015 Answers
SOURCE: my vitra soft close toilet
Chances are that the friction washers that control the closure rate are worn out. Most of these are not replaceable so you will need to get a new one. Thanks
Posted on Nov 18, 2010
Is there a replacement hinges available for soft closing toilet seat, It was purchased and Aldi 15/6/17 and has ceased to soft close.
i had a similar problem and couldn't find hinges so i just bought a new seat.....much easier
Aug 18, 2017 | Home
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
How do i fix a soft closing toilet seat
some of these have bolts under seat...you turn seat to left or right by grabbing while in closed position...this will release the seat from the holding bolts...then tighten the bolts....then reset the seat on bolts then lock down by doing the opposite as you took off...
Oct 10, 2014 | Home
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Can you help re fitting cedo rue toilet seat
Had same problem, this website has the instructions:
http://www.haro-sanitary.com/technical_intelligence_ENG_HTML.htm
Dec 08, 2009 | Home
Cedo Rue Toilet Seat Soft Close White EAN: 4016959076115 Just bought this - fixing instruction diagrams are unreadable. Can anyone help? Does anyone know if the manufacturer has a web site?
Just bought a Cedo Rue soft close toilet seat. Can't make any sense out of the useless instructions and what to do with all the bits. It also included an alum key which I can't see a use for. Can you please help
Nov 29, 2009 | Duravit Home
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Home Logo
105 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
