Question about Garden
Where do I get parts for gardenline hedge trimmer clutch drum is broken
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
jyackle5
  • 8197 Answers
SOURCE: parts list tanaka hedge trimmer
You can get the service manual on link below.
http://tanakapowerequipment.com/pdf/serv/Tanaka_HT_Service_Manual.pdf
On this link below is the parts list.
http://www.tanaka-usa.com/pdf/dpl/hedge_trimmers/THT-2100dpl.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jun 27, 2010
riceski
  • 1851 Answers
SOURCE: hedge trimmer broken
Any local repair shop will do this for you - if you're looking for free repair -then please - look at the local sears store to direct you as they have the locations there.
Thanks
Gary @ Fix Ya
Posted on Jun 30, 2010
eugbug
  • 479 Answers
SOURCE: oil/petrol mixture for GPHS 26cc gardenline hedge
Petrol / oil should be in ratio 50 to 1
Posted on May 13, 2011
Hedge trimmer revs but blades hardly move
Does it rev all the way up to the top end of the rpms, or does it rev but only a small amount, like if you had your car in drive and pressed the gas while stiffly holding the brake? That might mean your blades are too right and you Gould bring them in to be sharpened which will obviously include an adjustment. If it revs up like a food processor and nothing happens, it could be any number of things. First, be happy it runs at all. Now, it could be the gears are no good, the clutch is bad or the drum has separated from it's gear, or maybe the dogs inside that make the blades reciprocate have broken. The only way is to grab a 3mm Allen wrench and open up the lower cover for the gear case. I suggest finding a husqvarna dealer already located. If you determine the problem, I can assist with the repairs
Apr 03, 2014 | Husqvarna 225h60 / H75 Hedge Trimmer Owner...
Replacement of starter cord on HC-150 hedger
You may have wrapped it the wrong way. If not, your spring is either broken, the bend on the end which slides into the plastic has straightened, or the plastic spool has broken where it holds the other bent end of the spring.
Nov 07, 2013 | Echo HC-150 COMMERCIAL SERIES HEDGE...
I need to replace the clutch that is screwed on to the end of the crankshaft on my Stihl HS 45 Hedge Trimmer. How do I get the old clutch off of the crank?
Remove the plug and insert a length of old pull cord into the hole, makin sure to leave some to pull it out with. Also making sure the piston is at bdc, you turn the clutch counter clockwise
Oct 26, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Oil/petrol mixture for GPHS 26cc gardenline hedge trimmer
Apr 13, 2011 | Garden
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
Mar 01, 2011 | Echo Gas 20 In Bar Double Reciprocating...
Craftsman Bushwacker hedge trimmer year 2007 19" Has no spark is there an online assistance. Albert
I have a stihlfs40 "old one" 4130 model that the owner of the broken clutch fs40 could buy for spares.
Jun 25, 2010 | Garden
Garden Logo
606 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
