Question about Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80 flashing 'err' and 'off'
I started having trouble with my camera in a very humid environment but was only there for a short time. The 'err' message would flash and the camera wouldn't take pictures. Now it switches between sometimes saying "err" and sometimes saying 'off.' I can't find this anywhere in the instruction manual or online. Any ideas?
  • 7 Answers
Usually you get this kind of problem in variations of temperature. Humidity means moisture and that isn't good. The Nikon D80 body was not built for harsh conditions. Nikon define that any use above 85% humidity, or use near 100 degrees, plus any use involving moisture of any kind? including hands/body (camera resting on a shirt while walking) is bad. So it's not robust by any stretch of the imagination. The model is not made with environmental seals, like pro models. I guess they aimed this model at enthusiastic amateurs and didn't see the need. Trouble is this model can, in the right hands take pro-quality shots. I use two, like you, but I saw this problem coming and I never wear them suspended from the neck and put them away when they are not in use with plenty of silica gel in my bag. I shoot racing and I REALLY sweat! If you have the lcd screen up against you on a hot day it intensifies the heat. The problem is likely to be moisture on the PCB board, which causes corrosion to the board. If you've ever done gym class and the windows have steamed up it's the same thing. It's just means the temperature inside the camera is way too hot. Anything electrical causes heat, so the temperature on the inside is gonna be way hotter. If it is cooler on the outside it causes condensation. If you have dried it out and you still have problems it's gonna need fixing at Nikon. The bottom line is that it's fragile; that is alluded to in the manual. It sounds improbable but I can assure you that Nikon will tell you the same. It's not the sweat on your hands that is causing the moisture..highly unlikely. Hope that helps.
Posted on Sep 26, 2008
Woda to gej
Posted on Oct 10, 2008
I am recieving a error 1 message on my Canon RebelXT/Eos
ERR 01 is a lens communication error. Try cleaning the contacts on the lens and in the mirror box.
ERR 05 is a flash error. It is usually caused because the flash failed to pop up. This can be casued by something as simple as the flash hitting the brim of a 'gimme' cap or impact to the flash or most likely spillage of sticky liquid around the flash and its pivots.
The XT also is notorious for having the bottom right screw of the rear circuit board come loose and short out some function of the camera, or even blow the main fuse or damage the circuit boards.
Jul 12, 2012 | Canon Rebel XT / EOS 350D Digital Camera
Err message with Nikon D70
Is there anything else than the ERR? Hold on I will have to look it up, just a moment.
Oct 07, 2008 | Nikon D70s Digital Camera
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Err message on D70 and clock flashes
D70..err display...problem with the loader section switch,rotating while loading is open,so get it repaired.
Mar 07, 2010 | Nikon D70s Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
ERR sign
This sound like your auto flash is not popping up allot of the time this will give you a err message and cause a slow reauction to taking pictures causing them eather to be blurry or very dark some times. is your flash working? if it is then it could be you lens try a diffrent lens if you do not have another lens then go to a camera shop allot of times they will let you try out lenses to try to get you to buy one.
Mar 04, 2009 | Nikon D70s Digital Camera
Err
If this only happens when using the flash - then it is a problem of flash synchronisation.
If it happens all the time - then one of the shutter curtains may be sticking.
Either way, you should get the camera looked at by a repairer.
May 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Flashing Err and E/Error Problem
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
Dec 17, 2007 | Nikon N55 35mm SLR Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
1,491 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
