Question about IBM eServer xSeries 225
Hi, This is Afaq from Saudi Arabia, server down total 4 hard drive 36 gb bottom to top no 1 & 2 mirror os MS Win 2000 server in 2nd hard drive orange light blinking i was pull out and pull in again that time also server in runing after few mints by mistake no3 hard drive pull out and pull in again then automatically blue screen on and message is restart the machine i was restart but server not up when intilizaing msg is 3 hard drive dufcent only no 1 is up then next msg is hard disk boot failer insert boot drive press enter.
5 Suggested Answers
Hypnotoad
  • 55 Answers
SOURCE: wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Posted on Feb 14, 2008
SOURCE: hard disk upgrade
the above solution working fine, the ibm customer care people one REENA fails to answer this problem and she stop the chat section also verry arogent person. 1 TB segate hard disk sata working fine with x3400 sever and they provide 5 year warrenty also. thanks segate..
Posted on Jan 21, 2010
pavlicmaster
  • 171 Answers
SOURCE: We are using IBM X226 server with 4 GB RAM &
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Posted on Jun 28, 2010
info2u
  • 596 Answers
SOURCE: I am trying to install
A few questions:
1. Is this a new (clean) install? If so, have you installed the drivers for the RAID controller BEFORE you install the os? Most of the time Windows will ask for this as the os check your sysem. (You will see at the bottom of the screen "if you have a 3rd party controller and need to install drivers, do so now" or something to this effect.
2. If you already have an os on this system, (Server 2008) you may need to check the the HCL for SBS 2011 to make sure you hardware is correct for the install.
Good Luck
C2Solutions
Posted on Aug 12, 2011
Domain user
Hello Mr. Ali. I've been recently admitted to this Win Server 2008 R2 course. I had a class related to your problem, so I believe that I may help you solve this problem.
Click Start, point to Administrative Tools and then click Active Directory Users and Computers. Goto the properties of your created Domain Controller and scroll down to find this function "DSMmachineAccount", click to to change the value to Zero.
Hope this will work.
Sincerely Khurram Karim.
Jan 01, 2013 | Microsoft Windows Server 2008 R2 Standard...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I have a Dell Poweredge 1800 with 4 Cheetah 10K.7 Ultra U320 SCSI Drives which are supposed to be mirroring each other in case of failure of one hard drive the exact same thing is on the others. Drives 1...
hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
Aug 27, 2010 | Dell PowerEdge 1800 Server
Confuguring raid5
Hi
You would need 4 Hard disk drives in total. you would need to create 2 RAID 0 (striping) and then Mirror them (RAID 1). to elaborate, HDD A&B will be at RAID 0 as well as HDD C&D. after, you would have to Mirror your two RAID 0. (raid 0+1 is also known as raid 5)
Hope this helps.
Jul 09, 2010 | IBM x3400 Server
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
Jun 28, 2010 | IBM xSeries 226 Server
Humax pvr can not read my maxtor 500gb harddrive why is that?
NTFS
1)allows access local to w2k w2k3 XP win NT4 with SP4 & later may get access for somefile.
2)Maximum size of partition is 2 Terabytes & more.
3)Maximum File size is upto 16TB.
4)File & folder Encryption is possible only in NTFS.
FAT 32
1)Fat 32 Allows access to win 95 98 win millenium win2k xp on local partition.
2)Maximum size of partition is upto 2 TB.
3)Maximum File size is upto 4 GB.
4)File & folder Encryption is not possible.
I hope this clears things up for you
Mar 08, 2010 | Maxtor Hard Drive
Does Anybody know the GPRS setting of Apple iphone in Saudi Arabia ( For Mobily )
Dear Friends, HERE IS MOBILY SAUDI ARABIA GPRS SETTING / INTERNET SETTINGS HERE
FOR MMS Settings
1. Server Name : Mobily MMS
2. Gateway : 10.3.2.133
3. Port Number : 9201
4. Server Address :
http://10.3.3.133:9090/was
5. Connect Via : Mobily MMS
6. Size Limit : 100kB
7. WAP Version : WAP 1.2
FOR GPRS SETTINGS
1. Operator Name & Country : Mobily - Saudi Arabia
2. Network Name : WEB GPRS
3. Modem Name : WEB GPRS
4. Modem Access Point Name : web2 (web1 for postpaid lines)
5. Username : ""
6. Password : ""
7. Domain : ""
(if blank insert "")
8. Is there a tick in the 'This network connects to the Internet' box : Yes
9. Is there a tick in the 'This network uses a proxy server' box : Yes
10 Proxy Server Address and port : 10.3.2.133:8080
(10. IS NOT NECCESSARY TO ENTER)
ENJOY INTERNET AND PLEASE PRAY DUA FOR ME AND MY FAMILY take care - sameer2789@yahoo.co.in
May 25, 2009 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
Cannot install any Windows OS system
My first course of action would be to isolate the problem. So what i would do is un hook one of the 500 gb Sata drives. Then try to install on one. Once you get it up and running hook the second one up and let windows find it. Also another note of thumb is make sure you have not over exceeded your ram slot capabilities. Find the techical manual on the manufactures web site. Each ram slot has a max amount and speed. If you exceed these it can cause windows programs to halt. I do think that if you isolate down to one sata drive install your os then add your second Sata you should be good to go. If you are still having problems feel free to contact me. TechWizard
Sep 21, 2007 | Tyan Tomcat K8E Motherboard
IBM eServer xSeries 225 Logo
32 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
