Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C353 Tray 2 cannot be used curently That's the message and that's exactly what happens. Everything else works. No paper is taken from Tray 2.
  • Konica Minolta Master
  • 6,161 Answers
First remove the paper from behind the draws, that is probably what cause the problem. Then you need to get into service mode. Utility/counter, details, stop 00 stop 01, password 9272927292729272, system one, trouble isolate,
Find the draw causing the issue then your going "SET" then power off WAIT TEN SECONDS power on then go though the entire procedure again get to the screen and select UNSET. Power off WAIT Ten seconds power on. Your draw should show back up.
Set
• "Unset" is Default
• After changing the setting, touch [Decision] and turn the main power switch OFF and ON to make the new setting effective.
If the not get a tech out to look at the problem
Posted on Nov 14, 2015
  • 56 Answers
SOURCE: paper tray full message and not printing
Hi, first press "Menu" button on the printer,then press cursor down" button.When You have on display "status page" Press "enter" twice. printer should print a status page.If print, then everything is okay with printer and You need just to reinstall drivers.
Posted on Dec 27, 2007
SOURCE: SCX-4216 "No Paper" message
I've had this happen to my scx4521f a few times. I think I had too much paper in it. Or maybe it was poorly loaded paper. Take the stack of paper out and turn it around so you have no dings or dents on the inward facing side. You need to make sure that the paper is stacked evenly. Good luck. And now I will post my problem.
Posted on Jun 14, 2008
marked
  • 6487 Answers
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Posted on Aug 07, 2008
  • 163 Answers
SOURCE: False empty paper tray message
Dude,
If an“Out of Paper” message is shown on your computer and your printer cannot pick up paper, then follow the steps below (in the order) to resolve the problem.
Step 1:Checking the media and print settings:
  1. Remove power cord when the printer is ON, wait a while and then plug it back.
  2. Turn the printer ON.
  3. Place a Paper, which is not ripped, dusty, wrinkled, or bent.
  4. Place the papers of same size.
  5. Tap the stack of the paper.
  6. Verify the stack of paper between 10 to 25 sheets.
  7. Insert the stack of papers into the printer.
  8. Set the paper settings in the print driver.
    • Open a Document in the application, which has to be printed.
    • Click File > Print > Properties > Paper/ Quality tab.
    • In the Size Drop down menu, Select the Size of Paper.
    • In the Type Drop down menu, select Type of Paper.
    • Click OK.
  9. In the Print Dialog box, click OK to print .
  10. Try printing again.
    Note: If this step resolved your problem and you want to print on another media, change the paper in the unit, repeat steps 2 to 7 above for the new media.
this will solve your problem
Posted on Dec 16, 2008
SOURCE: I have a brother_mfc_9840cdw_laser_printer and
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. Sometime one side grips well and tries to pick the paper while the other doesn't resulting in a jammed. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Good luck & God bless!
Posted on Mar 03, 2011
Konica Minolta Bizhub C353 wrinkles all papers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Nov 07, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
Good morning, We have a bizhub C220 that is currently having issues. When a job is sent to the printer it won't automatically print as it states: 'tray cannot be used currently'. I can...
I had a c353, but the same error... I walked into work and someone had left the printer with this error... after looking online and having no results, I just turned it off (the hard power switch), and turned it back on, and it found tray 2 again!
Aug 12, 2011 | Konica Minolta Office Equipment & Supplies
I have HP laser jet 4350dtn heavy duty printer. It is attached with thye network point. And the configuration is done on the server. Then for the client machines I install via from the server since it is...
1 of 2 things. Either the paper type and size is not set right in the printer menu for tray 2. or the physical setting in the tray are not exactly on letter. The printer is looking for letter paper and does not see it in tray 2. If you load tray 1 with paper and press the green button my guess is it will use that paer and tray. First chack to make sure the setting in the tray are exactly on letter, it uses that and little fingers on the left side to tell the printer there is letter paper in the tray.
Jan 13, 2011 | HP LaserJet 4350 Printer
My HP LaserJet P4015n is making a high pitched noise when I print. It is also printing very slowly.
Same thing happened to mine at work. All because the paper tray indicator was not exactly on 'letter' size.
Remove the lower tray and remove all of the paper. Insure that the 2 paper size selectors are exactly on the marks for the size of paper you are using.
My HP4015N is now running at full speed with NO ANNOYING HUM!!
Nov 10, 2010 | HP LaserJet P4015N Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,642 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
