How do i increase emaachine from 126 speed to 512 speed
  • 20 Answers
I assume you are referrring to memory (RAM) from the sizes you are quoting. You need to turn off the power, open the box, ground yourself to remove static and look for the memory modules on the main board. They will be about 5" long, very slim and in sockets. They will likely be in pairs, so make sure you note which sockets they are in. Take the modules to a computer store ande ask for a pair of 256MB modules and replace them. You may be able to add it to the existing if there are free slots. Be very careful with the sockets as they can be easily broken, and keep any static away from the modules and the system. handle them only by the edges. If you are unsure, get some knowledgable help.
Posted on Aug 16, 2008
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
Increase graphics from 96 to 128
If you have insralled the correct video driver and you cannot increase the VIDEO RAM then it is not possible to increase the bit color from 96 bit to 126 or 256 bit color.
The only way to have a higher bit color is to install a new graphics card that supports up to 256 bit color (this video card will have large cideo RAM).
Mar 09, 2012 | Intel Desktop Board D865GVHZL Mainboard -...
I want to increase the memory ram for my HP Pavillion a 335 w , on my research so far I found that the largest memory it takes is the 512, it already has 1 gyga, in it, so I assume it has 2 512, I would...
the maximum amount of RAM for that pc is 1GB so upgrading isn't possible if you wanted to upgrade the speed of the RAM the maximum speed is 333 MHz which is not very fast so i would assume that's what the current RAMs speed is.
Apr 01, 2011 | Computers & Internet
How to speed up my computer
try increasing/upgrading your current memory(RAM)..eg..512 to 1GB. and also delete unused files in your temp folder
Dec 16, 2010 | Computers & Internet
My system ram is 512. but how do you increase the system speed level?
If you could follow the steps mentioned in the link below then you would surely see some changes
http://www.wikihow.com/Speed-up-a-Windows-XP-Computer
Nov 19, 2010 | Computers & Internet
I have a DELL with XP-Home Edition - version 2002 service pack 3, Intel(R) - Pentium(R) 4cpu 2.66ghz, 2.66ghz, 512 MB of RAM My daughter plays games and has 24 of them in the computer - she tells me I...
Hello, Jim.
Dell's official position is that the maximum memory for this PC is 1 GB. But, it may be able to support 2 GB, per Intel's specs.
But, to answer your question - yes - you can increase your memory amount to 1 GB. Since the system has 2 memory slots, you could conceivably have (2) 512KB modules (total 1 GB). If your system already has 1 module of 512 KB, you could add another. Just be certain it's the same type and speed.
Or, you could have a 1 GB module.
I don't think that your computer's life is in jeopardy, but additional memory always helps the speed of your computer.
Hope this helps.
Sep 19, 2010 | Dell Dimension 2400 PC Desktop
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Computer running very slow
Hello
Ok, firstly, the ram will not extend the life of your laptop, it will only give a slight increase in the process speed of your laptop, depending on how much you add.
You can buy the ram modules you need at any computer hardware store, they will instruct you on the best prices and how to install it. You can also try to buy it online(Ebay) where you will somwtimes get a better deal.
Kind regards
Andrea
Dec 13, 2009 | Averatec 6100 Notebook
Memory cards
Normally 512MB is a good configuration of Ram to work with Windows Xp Sp2 but you have clean your temporary files frequently
Increasing RAM will not give you much speed difference because first you have study the Motherboard Bus speed and the cache memory - Actual speed increase from those things and the compatibilty.
Changing Ram you have to determine what type of ram and its bus speed whether its a SD Ram or DDR1 or 2 I hope now days SD ram cost more because its outdated and DDR1 is also bit costly than DDR2.
Hothawk
Jul 23, 2008 | Intel Motherboard
How to increase my pc speed
You have to upgrade your RAM. 512MB is the minimum. Also you can increase the virtual memory. To do this right click on mycomputer, click properties, click on settings button that is next to performance, Click on virtual memory and then click on change. Set the value to 512. This will speed up your computer a little but stil upgrading your RAM is the best bet.
Regards,
Eagle338.
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
