Question about Lowrance GPS
Global map 5000 not loading fully. when switching ON main screen appears and information bar reads LOADING.loading bar reaches about 80% and screen turns white.leaving activated for up to 30 mins does nothing and unit cannot be turned off using power button.no other buttons or sounds will work during white screen stage. have checked that both SD cards are installed and seating correctly but to no avail.
  • nodgeiz May 27, 2011
    thankyou for your prompt reply and giving me alternative avenues to explore be discarding the unit.
  • 11,800 Answers
Have you followed the correct testing procedure? The one from here?
http://www.lowrance.com/en/Support/Product-Support/Troubleshooting-Guide/GPS-Module-Not-Responding/
If yes and it failed then the firmware is corrupted. Since you are no longer able to boot you will not be capable of fixing it yourself - the unit must be dismantled, the firmware chip accessed directly at hardware level and rewritten with a new firmware. This is a job only the main service shop of a dealer can do, you will have to send it to them.
If your unit is out of warranty you should call them before that, otherwise you might find out that it would have been cheaper just to discard this one and buy a brand new unit.
Lowrance Customer Service: 1-800-324-1356
Posted on May 26, 2011
My gps is lock home page will not reset will not cut off are onff or
I plunged mine in to the the computer and left it all night then held the off switch in for several seconds and mine reset plus I did an update before i shut it down. Hope this helps your's
Apr 17, 2014 | Rand Mcnally Intelliroute TND 510 Truck...
Garmin Nuvi 1350 - will not power on unless I hold power button down for the 10 second reset. At this point, the device powers on until it reaches the "loading maps" point and then shuts down.
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1350 Car GPS Receiver
Am loading new western european maps have got to step 12 says on some units only one option bar...press on 2 vertical bars or the menu icon...my screen doesnt show those vertical bars or a menu...
Could you please clarify what it is you are loading the maps onto? is it a palm pilot, gps, computer? and if so what is the make and model or operating system. if you can please provide me with these details i can assist you further. Thanks, Midwest-tek
Sep 18, 2010 | Computers & Internet
Apps on main screen won't fully close
This turned out to be just undocked apps from the quick access bar. I just had to drag them back to the quick access bar.
A more rigorous reading of the user's manual led me to this solution.
Dec 25, 2009 | Samsung Eternity Cell Phone
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
Switches itself off when I try to turn it on
possibly a bad battery try changing it To test its ability to load correctly connect to a power source and load maps. if it appears tow ork Ok then you need a battery change as when off the power souce there is insufficeient power to run the screen
Jun 28, 2009 | GPS
Lost all pay channels only normal channals work i.e bbc1,2... etc
Just Put new keys 28/11/08
00 04 4D 6F 7D D5 C9 F7 9B
01 16 CF 0C A7 A7 14 D2 22
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Lowrance Globalmap 2000
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
May 08, 2008 | Lowrance GlobalMap 4800 GPS Chartplotter...
530 hcx
You need to select all the segments at the same time and then transfer to the GPSr. Do not send one set, then another as the second set will overwrite the first set.
Feb 20, 2008 | Garmin Rino 530 GPS Receiver
GPS Logo
341 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
