What I am going to do if CPU has shutdown - Computers & Internet
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on May 26, 2011
When playing games on laptop hebirnating or shoting dawn
Graphics might be over heated. So it will shutdown.. go for advance version graphics chipset motherboad,. for better game xperience.,
solution: use heat sink., and check cpu fan., monitor cpu temperature..
System Shutdown During Gameplay
Jun 06, 2015 | Computers & Internet
Tip
Safe and easy shut down for regular Desktop users
Hai from Vishu
For Desktop Systems
when all applications are closed user can depress power button once for a second located on front panel of CPU(not the reset button) to initiate shutdown at one go when system is to be shutdown.( Applicable for all P4 cpu ONLY and not for older system where this action shuts down CPU immediately...)
on Jul 24, 2010 | Computers & Internet
How can I fix thermal shutdown of Acer b1-730?
Could be the CPU needs new thermal paste and reseating.this is usually a fail safe designed to protect the computer when the CPU is getting too hot.also check the cooling fan ......blocked vents as this may also cause overheating issues thus not cooling the internals which will activate thermal shutdown.
Mar 18, 2015 | Acer Computers & Internet
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
Always shutdown"CPU Shutdown Temperature
Hello download a manual here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_Driver_Detail.aspx?MenuID=61&LanID=0&detailid=1093
Check the bios for any cpu overclocking settings
and set it back to standard settings.
Renew also the thermal cooling paste between the cpu and the cooling fan.
See if the cpu fan is running when the pc starts.
Be VERY carefull when you remove the cpu cooling fan
and take care not to damage the cpu.
And take antistatic precautions when you work on the mainboard.
If you have not tryed this before let a expert do the job.
Hope this will help you
Nov 22, 2012 | EliteGroup Computer Systems Ecs...
It goes off automatically
Enter bios and check your CPU temperature, maybe it gets hot (optimal CPU temperature depends on CPU type, but usually it? not normal if it? above 65 *C) and because of that shutdown occurs. If the CPU temperature is high, apply heating paste between CPU and heatsink. Usually if the PSU is defective, the system restarts, shutdown occurs rarely.
If this is the solution for your problem, please rate my post, otherwise give us more details aboutyour problem.
Regards,
Andras
Sep 13, 2010 | EliteGroup 741GX-M Motherboard
Why does not cpu work on more tera hertze?
A CPU is specifically designed to work as a certain frequency. Some motherboards allow overclocking to speed up the clock frequency and allow the CPU to operate faster. The faster the CPU operates the more heat it will generate.
When a CPU overheats, it will shutdown - this is called thermal shutdown and if this is allowed to continue, the CPU will eventually fail.
Sep 09, 2010 | Computers & Internet
Laptop heats up and then shutdown
You could have a faulty fan which causes the CPU to go into thermal shutdown. The laptop will not boot up until the CPU has cooled down.
If the faulty is not fixed then eventually the CPU will fail.
Check the fan to see if it spins freely and replace if necessary. Also clean the heatsink and fan of dust.
Mar 02, 2010 | Lenovo 3000 Y410 Laptop
I HAVE P5RD1-VM ASUS BOARD NOW COMPUTER STARTED PROBLEM
several reasons for this.
1:) CPU Overheating.
2:) RAM Overheating.
3:) Motherboard Component Overheating.
4:) FAN not operating correctly.
These are a few things that can shutdown a computer after a few minutes, also viruses/trojans et,c.
can shut off hard-drives. and even instruct the bios to change settings.
Check that the CPU And case fans work correctly.
Mike @ compurepair.
Nov 17, 2008 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
