Question about Compaq Audio card Sound Card
I am having compac laptop and i am not able to listen music b coz of the disable of the sound icon so how can i enable it
    Genius:
  • 1,354 Answers
Hi
if your using windows7 and not getting sound just go to following link you will have your solutions
http://www.sevenforums.com/sound-audio/20962-cant-re-enable-audio-laptop.html
Posted on May 26, 2011
How do I fix my realtek speakers? They play sounds and music but while doing so the sound icon in the taskbar is showing movement from bottom to top with sound increasing as it goes upwards?
Open Device manager and right click on "Realtek HD Audio"
Select 'enable'
Right click on the speaker icon in the taskbar and select 'Playback devices' ensure that Realtek is checked as the default speaker device
Right click alongside the speaker icon and make sure they are not disabled
Use the 'Test' facility to check the audio
You may have to update the driver as well
Jun 25, 2015 | Realtek Semiconductor Realtek High...
How to turn on bluetooth on my emachiness em350
Check the control Panel, It will have Bluetooth Icon or Device Manager will show under networking, Bluetooth device. Check if is enabled. If it is disabled you can enable it from here.
You might also have to check View in Device manager for hidden devices.
Sep 27, 2014 | Computers & Internet
No sound on laptop hooked to pre-amp/amp
Assuming a Windows PC, go to Control Panel and locate the Sound item (Start button->Control Panel->Sound, should have a speaker logo beside it). Check the entries there and see if one of them is listed as disabled. If so, right click on it and choose enable. I would then disable the laptop speakers (so you don't have an echo from both sets playing simultaneously; right click the laptop speakers item in the Playback section and choose Disable). The go to the Sound icon in the lower right of your desktop (by the date and time) and unmute the sound. MS has plenty of help online for testing sound to make sure the devices work.
Jul 22, 2013 | Computers & Internet
When I connect my laptop to internet through USB then there is no sound from the laptop. Please help
HI
Without Internet u get the sound, if yes, then sound driver is ok now i think when u want listen the music or video online there sound option is disable u just enable the sound option u will get the sound.
May 07, 2011 | Samsung N150 (36725723009) Netbook
No sound device on my satellite c650. cant play music
You should have on Board sound "Toshiba Bass Enhanced Sound System". You can check in Control Panel at the speaker icon or, if you have a speaker icon in your taskbar, lower right of your screen, right click on it. A window should come up and you should see "enable" or "disable" . If you see "enable" click on that, and exit. Right click on the icon again and left click on "open sound mixer" and adjust your volume.
Mar 15, 2011 | Toshiba (4CH-VOUT) Sound Card
Hello, i have a problem with my sound. i can not listen to music. i have tried installing the sound driver but it does not work.
Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Now next you can do is
If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Feb 02, 2011 | Compaq Evo N600C PC Notebook
How to unlock touch pad of the hp compac presario cq62 model laptop ?
You can do it from Mouse properties, by going to synaptics tab, Select, Touchpad Disable Zone Settings, and uncheck Double tap to enable or disable touchpad....
Think you got the steps....
Dec 14, 2010 | HP Compaq nc6000 Notebook
A few days ago my acer aspire one's sound is laggy so i cant watch movies music videos or listen to music
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Oct 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
Toshiba Satellite Pro A200 - Vista - Sound problems
You should check if in the device manager the sound card shows up. Also, check the BIOS to see if it is not disabled.
Oct 27, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
