Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
My 802.11 b g wireless LAN - Belkin (F5D7050) 802.11a/g/b Wireless Adapter
  • 35 Answers
You need to specify your problem please
Posted on Aug 16, 2008
2 Suggested Answers
hawk127311
  • 350 Answers
SOURCE: I lost my instalation CD and i dont hav the
The link is not working, so copy and paste the following into your browser
http://www.xterasys.com/support/drivers.htm
scroll down the page to the correct drivers, download and install them and you are done. There is a user guide on the site as well if you want it. I hope this helps and good luck. Please vote and leave a message.
Posted on Oct 30, 2009
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
Disable wireless lan
Hi Bounthavee S,
I understand that you want to disable wireless LAN
In router :
Open Internet Explorer
Go to 192.168.1.1
This is home page of router
Type the following user name and password when prompted
User name admin
Password admin
Click on LAN Settings on the leftside menu
Right side, you may find option to disable the Wireless LAN
Click on Save settings at bottom
Router will reboot and take 3 to 5 minutes
Check if the Wireless LAN is disabled.
In one computer :
We need to disable the Wireless Adapter
Goto Start >> type devmgmt.msc in the search box and press enter
This will take to you Device manager
Expand the Network Adapter
Right click on 802.11 (wireless adapter) and select disable.
This will disable the Wireless LAN only in this computer
Oct 03, 2013 | Trend Micro Computers & Internet
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
Please follow the procedures below for installing the Mini PCI Adapter driver:
Installing Wireless LAN driver for Windows XP
1. Click the Start button and then click Run. The Run dialog box appears.
2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe"
3. Click "OK" to implement the setup program to install this driver.
4. Click "Next" twice to continue the installation.
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
Jan 21, 2011 | Everex StepNote NC1500 Notebook
I hsve problem with wireless driver in toshiba satellite l455-S5000 in windows 7-32bit its done install wireless driver and windows see wireless lan realtek RTL8187B wireless 802.11b/g 54 Mbps but...
Intel Wireless LAN Driver for Windows 7 (32) Posted Date: 2016-09-21 ' Version: 12.4.1.11.0 ' Size: 4.43M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 1.0.0.196.0 ' Size: 21.82M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 8.0.0.144.1 ' Size: 21.79M Realtek LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 7.003.0522.2009 ' Size: 7.26M pls remove the back cover and check wireless card label and download the correct driver.
Oct 01, 2017 | Toshiba Satellite 1415-S105 Notebook
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Belkin wireless g router 2,4 ghz 802,11 g
Whats the model number of this Belkin router?
Oct 16, 2007 | D-Link DI 514 Wireless Router (DI-514)
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
22 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
