Question about Honeywell Eclipse MS5145 RS232 Kit Black with Power Supply Auto Trigger Codegate Software Handheld Barcode Scanner
I've a problem to connect my MS1545 RS232 to my computer.ther is any led on.please help me
Yamaha aerox 100cc
Engine seized
Jun 30, 2013 | Motorcycles
How to connect to internet in laptop using nokia phone
I have got internet connection from my slide (EDGE). Nokia PC suite seems to offer such a connection via Bluetooth through my phone by calling it One Touch Access. Bluetooth connection is perfect, my phone alone connects to the internet but not my laptop through my phone. What needs to be done?
Oct 06, 2012 | Computers & Internet
Turning back on the LED side lights on my Asus laptop.
Please share the laptop make and model number
Oct 06, 2017 | ASUS Computers & Internet
Hello guys. I need help with my hp dv4 1225dx pavilion. It all started with not powering with battery power. But the battery is in perfect condition. When I plug in the power cord. It comes on and I...
It sounds like a hardware issue, if you're getting the LED's blinking when pressing power, there IS power to your mainboard (which is a good thing). Some manufacturers have placed LED blink codes within the system to let you know what's going on, but I have a feeling it's either A) your battery or B) your hardware, such as a bad RAM stick.
Try removing the battery and with the power plug connected switch the laptop on. If it works, you've got a bad battery.
Try removing a single RAM stick or replacing both.
You could search HP Pavilion LED blink codes to further address the issue.
Jul 18, 2012 | Computers & Internet
I've got an intel db43ld that won't post. The green and red LEDs on the motherboard are blinking. I've tried to replaced the motherboard, memory, and power supply and the lights are still...
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Aug 30, 2011 | Computers & Internet
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
What is the RS232 port for?
RS232 is simply a serial data transmission / communication port. It has never had any signals involved in video. It has been used for data exchange between computers and for connecting peripheral devices like modems and printers to computers. It also has been used to connect a remote keyboard / screen, such as a "dumb terminal", to a computer as an additional I/O device.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 19, 2011 | iLO 3200 32 in. LCD Television
I need a laptop with RS232 port. What model should I get?
RS232 is now not being fitted to laptops This has become old technology. If you have devices that require connecting via an RS232 There are USB cables that emulate the connections of an RS232 that can be set to a com port to fool the device that it has the rightr connection. Look on Ebay there are quite a few at various prices, most from Hong Kong. I have bought aqnd used them to connect my radio scanners and Scancat software to program Amateur radios quite succesfully, as well as to run my old HP A3 scanner
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Toshiba Satellite M35X-S149 Notebook
Honeywell Eclipse MS5145 RS232 Kit Black with Power Supply Auto Trigger Codegate Software Handheld Barcode Scanner Logo
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
