Question about Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum
No power apparently, no light when switched on at mains. Has been working fine
How do I fix the power button for my Dyson DC14?
  • You will need to remove the switch cover and replace the main power switch.
Jun 29, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Agitator wont turn
It could be one or more of a few causes. Easiest to check is the belt and/or brush roll. There are two switches for the brush roll. Both must be working properly. One is by the main power switch and the other is in the motor compartment. If the problem still persists check the brush bar motor in the power nozzle assembly
Feb 23, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
Has no power
Does the switch feel like it "clicks" when you turn it on? might be a bad switch. If the motor went bad then it's lights out for that vac.
Jun 09, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I vacuumed last week and it worked fine. Now I turn it on and the light is the only thing on. What is wrong?
Hello Jeannette, you unit probably needs a system maintenance. Their are quite a number of possible problems affecting your unit.The belt could have cut thereby not rolling the motor, the motor could have become bad and the control board could have gone bad. Although apparently since the light still comes on this indicates that the power is still supplied into the unit. trouble shooting tips for vacuums differ what is the exact make and model of your unit? Let me know this so i can provide more exact answers for your problem.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Sep 27, 2011 | Bissell 8975 CleanView Bagless Upright...
Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
Vacuum head stopped working, unresponsive to on/off switch and light bulb is out. Canister otherwise works fine. Help!>?
Power head on/off switch could be faulty, Wires running through hose may be broken, electrical connections may be burnt.Motor in Powerhead could be dead.
Nov 17, 2009 | Vacuums
Power Switch for Fantom Lightning
I think that the marking is 5E4, not SE4
Nov 18, 2007 | Fantom Vacums Lighting Canister Vacuum
Kirby G3 won't run
sounds like brushes not being pressed down to the commutator shaft. pull out brushes and clean the brass brush guides and then apply a light coat of grease to brushes. however, what exactly do you mean by "the fan is OK"?
May 29, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Dyson DC22 Motorhead Canister Vacuum Bagless Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
