Question about Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD)
I just bought a new lap with ST9250315 AS HDD and i can't install winXP on it. First setup crashed, but i changed the BIOS setup for IDE instead of AHCI. After that installation goes ok until i needed to format disk from FAT 32 to NTFS, when system reboot just doesn't run again, a grey screen appears and nothing happens. however bios work without problem. what can i do for fiz this issue? thanks
  • 21 Answers
Sometimes, recent hardwares (laptop components) don't have its drivers for XP1 & 2. (It conflicts.)
Try with XP3. Otherwise, you have to reinstall win7 and run win XP virtually under win7.
Posted on May 26, 2011
I used winxp home service pack3 to format my hp mini laptop, when i do the setup it got an error saying " did not detect any hdd on my laptop, when i try to setup windows 7 my hdd would be...
The Windows XP disc you are using doesn't that the Hard Drive Controller Driver for that system native to the operating system. Since the system is a Mini and has no floppy drive the only option is to slipstream the HDD controller drivers into the OS CD.
http://www.fixya.com/support/r4439741-integrate_slipstream_sata_drivers_into
Jan 27, 2011 | Computers & Internet
I have hdd sata and i want to setup win xp on it but i cant winxp can not cont
Check your BIOS setup for the SATA interface settings. If it's set to "Native" or something to that effect, change it to "Compatible" or "IDE" or similar, and try installing XP again.
As a last resort, you may need to supply SATA drivers for your motherboard (unpacked, with all the individual files visible) during the setup, when it says something like "press [something] to supply 3rd party device driver". The problem is, that Windows expects it on a diskette...
Jul 02, 2010 | MSI PM8M-V Motherboard
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted, and the BIOS is set to recognize CDROM, HDD, and so on. The SETUP is still stating that it can not see the...
You need to go into the BIOS and change the SATA type to IDE and not AHCI. I had this same problem on my laptop. Once I switched it to IDE it installed XP no problem. I don't know if Vista or 7 work with it set to IDE mode.
Nov 28, 2009 | Gateway CX2724 Notebook
Displays no hard drive found wen installing win xp
You have to go to BIOS setup, find HDD setup, and change the value to the other one (there are only two possibilities). That will fix your problem. The problem is caused by the fact that the lap top was designed for vista, not XP. and the lap top contains SATA HDD. when installing XP pre-installation doesn't have SATA drivers, so your OS can not see the HDD. Change it in BIOS, and you trouble is gone
Nov 14, 2009 | Toshiba Satellite A200-19501F Notebook
IS HD161HJ COMPATABLE WITH MS-6741
Be sure that SATA is enabled in your BIOS settings. Sometimes if the computer ships with an IDE drive, the company that builds them will disable SATA in the BIOS. Also, while you are in your BIOS, if you decide to use just the SATA drive, you need to disable your IDE and set the bios up to boot the computer from your new drive on the SATA connector.
Mar 27, 2009 | E-Machines eMachines Refurbished EMA...
I can't install winxp in my l45-s7409 laptop.
go in to the bios setup and somewhere in there is sata native disable it.. or change to ATA in bios
Aug 13, 2008 | Computers & Internet
Help in need of advice
Try to delete the partition of your HDD and then create another one an format it to NTFS. Set the bios to boot from CD, Once the setup disk for XP loads, Try to follow the steps I provided.
For the Best OS, you need to make sure the computer is able to get the requirements for certain OS.
For WinXP atleast 256 MB RAM(recomended 512mb),For Vista 512MB(recommended 1gb)
May 10, 2008 | Intel Server Board STL2 Motherboard
My new HDD isnt showing up in my computor
What type of HDD is your new one? SATA, IDE?
Do you have any USB disk devices plugged in to your system? USB hard drive or flash stick or other SD cards? Remove them and try rebooting again. These can sometimes take precedence over your HDD and your system will not boot.
Mike
Jan 21, 2008 | Computers & Internet
Doesn't Boot after New Install
try changing the boot order in bios connect the hdd and set it to boot as the first device check that ide is selected rather than sata
Oct 27, 2007 | MSI PT880NEOLSR Motherboard
Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD) Logo
439 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
