Question about AGA ILVE M-90F-MP Dual Fuel Range
Have an ilve oven with a digital clock timer the timer is going on and off it goes into timer mode and you cannot set the time at all mod. el 198 does it need replacing and what would it cost
2 Suggested Answers
  • 149 Answers
SOURCE: Ilve electric oven modle P 90 WMP. the digital
on the back of the clok is 4 wires the brown and the blue suply power for the clock and timers functions the 2 reds the timer makes these live if only one is live when set to manual then its best to replace the clock or if you can change the relay that the wires ar conected too
Posted on Mar 23, 2010
Set the hour on clock on GE electric stove
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Setting clock on GE electric stove
Range Setting the Clock and Timer Non-Electronic Clocks: To set the clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
Digital Clocks: To set the clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
Electronic Clocks: To set the clock touch the Clock pad. Touch the number pads. Touch the number pads. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Hi, my ilve oven made a bang last night blew the fuse in the fuse box, which I replaced. The lights and fan on oven work but there is no heat.
Hello westcowie, ILVE Service here.
First check that your oven's time is set. If the clock is not set the oven will not work due to a safety feature following a power outage?
If you continue to experience problems please contact the National ILVE Service team on 02 8569 4672, or via the ILVE website at http://www.ilve.com.au/contact-us
Thank you, we look forward to helping you with this issue.
Kind regards, ILVE Service
Jun 14, 2011 | Kitchen Ranges
I have just installed an Baumatic wall oven mod. no. B605MS.1. The clock has lit but the oven does not actually switch on and heat. Please help. Thank you
The electronic timer/clock must be in the manual mode for the oven to work. Consult your instruction booklet and set to manual. Your oven will then work.
Mar 07, 2011 | Baumatic Ovens
Jan 24, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
AGA ILVE M-90F-MP  Dual Fuel  Range Logo
164 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
