Question about Gigabyte GA-8I865GVMK-775 Motherboard
Motherboad not working - Gigabyte GA-8I865GVMK-775 Motherboard
    Sergeant:
  • 207 Answers
Most motherboards nowadays don't work at all if the CMOS (Complementary Metal Oxide Semiconductor) battery has emptied out or weak, remove the battery and test it with multitester, a good battery is about 3V or higher, a 2V reading or below would post a serious problem on the CMOS program of the motherboard. If you find the battery is weak replace it with a new one. If these steps doesn't work at all then you should look for other problems. Observed any bulged capacitor where the upper cover is slightly push upward and remove them if you find one using soldering iron and replace it with a new one with the same rating, but if you can't find one just try removing the motherboard from the main system unit, remove the CMOS battery and clear the CMOS for about a minute or more. You should drain any power left from the motherboard's capacitors that keep supplying the CMOS battery. You could use an aluminum foil to shorten out all the circuits under the motherboard to drain the circuits out. Draining the circuit simply putting the system on all default position. After doing this you can now put on the CMOS battery, put back the CMOS jumper setting to default and inserting all the components for testing.
Posted on May 26, 2011
  • Gigabyte Master
  • 32,281 Answers
If you the power LED does not light up, then the switch mode power supply may be faulty and must be replaced.
My laptop will not trun on motherboad issuse
You just asked the question and answered it yourself. My laptop won't turn on? Answer . Motherboad issuse!
Jul 03, 2010 | Everex StepNote NC1500 Notebook
My 845gvsr motherboad showed no display problem,in...
If your keyboard linked three lights thats mean its not a problem of motherboard check your RAM or Connection of HDD.
Regards.
Andy
May 21, 2010 | Intel Motherboard
Motherboad drivers
You can goto dell and download the drivers at http://www.dell.com .
Jun 13, 2009 | Dell Dimension 4600 PC Desktop
Motherboad haang bila dipasang video card external
If you can't get the "dipasang" off of whatever it's attached to, then try carefully removing the "dipasang" from the "motherboad".
Mar 16, 2009 | Compaq Computers & Internet
AV8 Motherboad post code C5 freezes on boot.
Hi...
Try cleaning the contact point of the memory modules "with a pencil eraser" and insert them back... Clean also the Processor heat sink if dusty... Then check the voltage of the CMOS (3V) battery it maybe dead, if so you need to replace that with the same type.
Keep me posted if still does not work...
Happy fixya...
Feb 28, 2009 | Abit AV8 Motherboard
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
Gigabyte GA-8I865GVMK-775 Motherboard Logo
222 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
