Question about Carrier Heating & Cooling
Work on carrier roof top unit model # 48tje006---301-- replace compresor put unit in a vac and charge unit up but when i start unit no head presser on low side and 100to 110 on high side i think the metering or cop tube has no restrions and i am thinking i am reading complete unit presser on the high side yes or no
koolbreezes
  • 540 Answers
SOURCE: Haier central ac unit problem
HEY,Kim, connect the red hose with the crooked end on the small line service vale and the blue crooked end to the fat line service valve and read the preassure now. Also the yellow line connect to the refrigerant tank...!
Posted on Sep 07, 2008
  • 11 Answers
SOURCE: Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Posted on Feb 09, 2009
SOURCE: seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Posted on Jul 24, 2009
  • 22 Answers
SOURCE: fan on Carrier roof top ac makes loud noise on
sounds like bearing is out on motor or blades on motor are out of balance you may have to replace both it can also be bearings in the evaporator motor if its a package unit or even something caught in the evap squirl cage.hope that helps you
Posted on Sep 29, 2009
shastalaker7
  • 1515 Answers
SOURCE: , Compressor start capaciter MFD value: roof top RV Dometic unit
Hi, I did some research and found nothing on the a/c unit. If I had the model and serial numbers from the condenser and compressor this would help me. This would be a run capacitor doing the start up, dropping out the start relay and keeping it running. If you have only one run capacitor and its a dual, will have 3- female spades coming from the top, with marks that say Fan, C for common, and Herm. for compressor. If it has only one capacitor with2- female terminals, several places to connect more than 2 wires, its a single cap. If it just runs the compressor, it could be a 370 volt x 20, 25, 30, 35, uf?? If its a dual it could be a 370 volt x 5 u f for the fan and the same , 20, through 35 u f or microfareds. The best way to find out is to take off the wires on it, and make sure you draw a diagram so you know they are right, and take it to a appliance parts house and let them check it to see what they are. Larger units can have a 440 volt x 20 to 35, 40, 45 and so on. Your unit is not that large, so it will only be 370 volts as far as voltage, but the u f value will need to be checked with a meter that will check the value of these and give you a number such as 4.99 u. f. and you will no its a 5 u f. It may be higher like 5.24 u.f.and that is OK. Make sure the capacitor has no oil leaking from it or its not swollen looking or distorted in anyway, it will be open or shorted out. Please let me know if I have been of help to you when you go to rate me, please be kind. I will be here if you need my help if you are having problems with the compressor not starting.
Sincerely,
Shastalaker7
A/C & Heating Contractor
PS If this capacitor is black plastic and mounted on the side of the compressor, it will be a start, run capacitor with 2 wires. It snaps in a metal type holder you will need to take it out and check the terminal area it was connected to and remove it. If only 2 wires, it won't make a difference what side the leads hook to.
Posted on Jul 03, 2010
Testimonial: "This is exactually the information I was looking for. The paper label on the black plastic cse was faded, and I wasn't sure of the u f range this comperssor needed. Thanks, G"
Trying to find weight on a carrier roof top unit
ring carrier direct on the phone , tell them what model you have and they will be able to tell you
Aug 22, 2016 | Carrier Heating & Cooling
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
I have a carrier visionaire model LCA061P and i am in need of the fan assembly or part # for it it. any help would be appricated
Something fell from the roof and broke the top (outside) of my
visionair a/c unit. Can I replace the part? It's near the circle on
top and finally part broke away and can't be found
Smurfsters@aol.com
Aug 13, 2010 | Carrier LCA061P Air Conditioner
New compresor and condenser. aircondition do not work
has it been converted to 134a if so did you put a new orfice ,dryer ,did e-vac the system before charging
Jul 11, 2010 | 1996 Cadillac DeVille
I have a kenmore elite , Mod# 71203100 mfg=10/10/2001 it worked fine since I got it ..48 hrs ago it was found to be not cooling anymore, lights go on fan's work , but compresor will kick in for 30 sec and...
I would fix it because The way I am understanding the compressor is getting hot and thermally kicking out. This could be a thermostat or a start relay for the compressor. Or it could be low on charge that will also make the compressor shut down because of the head pressure. I would check out my thermostat really close and any start relay's for the compressor. It would be about 200.00 compared to 1200.00 to replace it.
Jun 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
The compresor wont start and it's getting very hot!
Check the capacitor. It is in the outaside unit. Siver with three terminals on top. If it is swollen it is bad. Check for burnt wires. You can repair these yourself. Compressor maybe stuck. If it is an old unit you will have to replace it. Rusty
Jun 08, 2009 | Heating & Cooling
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
COMPRESOR TROUBLESHOOTING
This is a typical symptom of having an A/C system low on freon if it cycles on and off when first turned on or very soon afterward. All types of A/C units for home and auto have a low pressure cut-out switch that will disengage the compressor when the freon level drops low enough to cause damage to the compressor. The unit needs recharging with the proper amount of freon to correct the problem. If it's an automobile A/C system and the freon level is okay, it could be a faulty compressor clutch or coil.
Oct 16, 2007 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
203 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
