Question about Panasonic Lumix DMC-FZ20 Digital Camera
Battery drains battery keeps draining down bought new battery same problem needs recharge in 4 days power safe works on -off switch works
I too have problem with camera on/off switch . Solved the problem by charging battery fully and installing only when I needed to take pix. Then removed it when not required. I found I could open battery cover and remove battery while camera was 'on' as an emergency measure, without apparent damage.
Posted on Nov 17, 2008
Got a 2008 GMC. Acadia. Battery down after 4 days of not being started. Has a new battery. Charging system charges great.
There is probably a small drain on the battery - perhaps the luggage compartment light isn't switching off.
The car alternator isn't really capable of recharging a battery due to it's high internal impedance. It is better to recharge it independently.
Mar 23, 2017 | 2008 GMC Acadia
Need to get power to the car. It will not receive power from a new or charged batter to turn on lights, the computer or ignition switch. Will drain power if left attached to battery for a day.
There may be a "fusible link" hanging off the side of the battery that might be blown. That could explain the "no power" problem. Once that's fixed, you can begin to find where the heavy drain is.
Oct 26, 2015 | Cars & Trucks
My 2009 honda civic keeps dying...Bought a new battery..Changed water pump, ac pump and somthing keeps draining battery. checked all lights inside car..They did alternator test..Please help?
you don't say how long it takes to run down it sounds like you have something that still switched on does it loose power after you have driven somewhere or just overnight
Apr 10, 2014 | Easy Quick Auto Jumper Recharges Vehicle...
Battery keeps going flat
Check alternator voltage output, might be low. obd2 scanner
Jun 12, 2013 | Cars & Trucks
S7000 drains batteries very quickly
1)teh batteries are not the right typ use or alkaline or only NIMH
2) if shooting a cold area, keep the batteries warm by placing them in a inner pocket, until you ready to use them
3) battery terminal are diry, wipe them very well, with cloth and ethylic alcohol to 70%
4)the batteries have not been used for over a year.
God bless you
Sep 22, 2012 | Fuji FinePix S7000 Digital Camera
When the bike is switched off the battery drains
If the battery is getting old (4 to 5 years) it may not be able to hold a charge as well as it did. Have it tested, it may need changing. If an alarm is fitted to the bike it will drain the battery as it will use power even in standby mode.
Mar 12, 2010 | 2000 Harley Davidson FLSTC Heritage...
My 2000 lincoln ls battery keeps dying have bought 2 new batteris same peoblem is something draining the power?
Either something is draining the power or your alternator is not recharging your battery. Do you have a DC voltmeter? With the engine running check the voltage accross the battery it should be about 14 volts. If it's down around 12.5 volts with engine running the alternator is not working. If you determine the the alternator is working and the battery goes dead, then there is a draw on the system. It could still be the alternator though, there are diodes in the alternator, a diode acts like a one way gate for electricity. With one bad diode the alternator will still work but, when you shut the car off the alternator drains the battery back down. Something is drawing it down, without testing equipment, you'll have to take it to a shop. Something you could try, after the car has been shut off for while, an hour or more, go feel if the alternator is warm or hot, if so it's drawing the battery down. Disconnect the battery overnight so it doesn't go dead on you.
Jan 05, 2010 | 2000 Lincoln LS
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
Battery drained dead in ocld weather
Could be both batteries went bad.
1) I would take battery back to where you bought it and have them test.
2) Check, or have someone check, that battery power is not being used when the key is off and the car is not being used in any way. There will be a slight trickle of power use, but nothing that would wear the battery down in less than 3-4 weeks.
Jan 24, 2009 | 1993 Buick Century
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
Panasonic Lumix DMC-FZ20 Digital Camera Logo
241 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
