Yellow line that is faint yet visable down the right side of my tv
  • 927 Answers
Good Day, brandondotta;
Yes that yellow line can be annoying. Does this happen when you view your DVD? NO, suspect reception. Yes, suspect bad panel, inverter or TV ' high voltage circuit arcing.
Good Luck, big Irish.
Posted on Aug 16, 2008
One yellow, one pink, and one blue spots appeared on my tv screen.
The set if projection which model here is, has arced and now each of the three picture tubes used has a tiny permanent burn mark on its screen.
That is what you are seeing, the set uses three picture tubes with screens like the old tv sets===the coating has been burnt in each, want to prove it, remove rear cover and cover any one of the three lens and that mark on one tube will go a way.
Not fixable.
Dec 23, 2012 | Mitsubishi WS-55315 55" Rear Projection...
Faint red lines in a curved arch like pattern
For this problem, what you have to do is here I found this solution: Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labeled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up. That should do the trick, Hope this is helpful. Please dont forget your rating.
Jan 26, 2008 | Sony KP-51WS500 51" Rear Projection...
Toshiba Model 51h84
The wavy when cold is a issue with a board in the set--Hyper board--the warmup until it begins to work will gradually get longer and longer.
The blue: look at set on a unused video input--if see faint curved blue lines with some blue visable on the screen the blue screen control needs to be adjusted just slightly down until the blue and curved lines are not seen.
May 15, 2012 | Toshiba 51H84 51" Rear Projection...
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
May 05, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
Sony KP-57WS520 57 in. Rear Projection HDTV-Ready....white horizontal lines on screen. how can this be fixed
Are they faint lines that are visable while watching the TV or is it just a white screen with white diagonal lines in it and then it shuts down? Also is the sound heard?
Sep 01, 2010 | Televison & Video
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
I have a line that goes from the top to the bottom of the screen, when on the blue screen I can see it well, but when watching tv you can see a faint yelloe line in the same place. (right side of screen)
I have a toshiba plasma 1080p thats all I know, I see the line the clearest on the blue screen, you know when you change to an imput that has nothing using it, and when watching tv or games a very faint yellow line you gotta really focus on to see. But I wanna make sure this is not gonna get worse. Thanks for your response let me know.
Aug 15, 2008 | Televison & Video
Replace your transfer belt!
Jul 22, 2008 | HP Color LaserJet 2600n Printer
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
