Question about Canon PowerShot G10 Digital Camera
Lens error restart camera - Canon PowerShot G10 Digital Camera
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on May 28, 2011
Lens error.. I have restarted & restarted camera..still same lens error
May 20, 2010 | Canon PowerShot A420 Digital Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Lens error, restart camera.How can I restart the camera IXUS 60?
Since the camera is locked after lens error, you will restart camera removing batteries.
If this does not help, then you are in one of the following conditions:
Lens error and lens does not retract.
Try helping lens gently back in while you turn off the camera holding the button at same time.
Lens error and lens do not extend.
Restart the camera , and try gently tapping the camera back with the palm of your hand whilst restarting camera at same time.
If that does not help, then one part on the camera lens assembly is broken or out of place, or dirt inside lens mechanism caused the fault.
The lens must be disassembled by a technician to fix the problem.
If the problem is not fixed swapping batteries and resetting, then the camera must be taken apart and tested by a technician.
Here you can get a quote on repair: Repair
Aug 22, 2009 | Canon Cameras
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 28, 2009 | Canon Cameras
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
How do i restart my canon camera?
Restart means turn it off and on. But I believe that you failed to mention the other words that go with this error, namely "Lens Error, Restart Camera". Sadly, restarting the camera usually does not work to correct the lens error.
Oct 11, 2008 | Cameras
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 31, 2007 | Cameras
Canon PowerShot G10 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
