Question about Intel Desktop Board D845BG (KD845BGPAK10) Motherboard
Sibnal name of Front panel connector - Intel Desktop Board D845BG (KD845BGPAK10) Motherboard
    Sergeant:
    Habit-Forming:
  • 200 Answers
GET COMPLETE DETAILS AT http://www.intel.com/support/motherboards/desktop/d845bg/sb/cs-013120.htm. PLS REPLY OR COMMENT OR VOTE.
Posted on May 26, 2011
Emachine W3653 motherboard manual
Intel 945GCT-M3 motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rmv.shtml
Above shows main view, and is labeled.
http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtml
Click on Product Views for Pinouts and connectors for;
1) 4-pin ATX +12 Volt power cable; B - Processor Core Power Connector
2) Processor fan cable connector on motherboard; D - CPU Fan Connector
3) 24-pin ATX main power cable; F - ATX Power Connector
4) Floppy Drive 34-pin connector on motherboard; G - Floppy Disk Drive Connector
5) CD/DVD drive that is IDE (PATA) type -> connector;
H - Parallel ATA IDE Connector. (Harddrive goes to SATA connector)
6) Computer case fan connector; I - System Fan Connector
7) Audio connector on motherboard for CD/DVD drive's small audio cable, (Main drive if there are two)
M - AUX-IN Connector
8) Front Panel is front of computer.
N - Front Panel Audio Connector is where the front panel audio ports connect.
9) R - USB 2.0 Connectors = Front Panel USB connectors on motherboard
10) Front of computer is the Front Panel. Area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
T - Front Panel Connector = Front Panel header
Motherboard manual from ECS Support,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=719&CategoryID=1&MenuID=16&LanID=0
(Note photo is distorted. Click on - More pictures for clearer view.
{More pictures / Where to buy / Print )
Click on the Download tab.
(Features / Specification / Download / Support / CPU / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down, click on the country NAME nearest yours.
A PDF file motherboard manual will come up.
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 16, 2012 | Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I am having a problem connecting my power supply to my motherboard i can plug in everything except the one connectors that require a connection to a part called PWR-LED
Take a look at the picture below:
If I am right, the Front Panel connector should look similar as shown above (it's an assumption since you didn't mention the Motherboard's name and version). Look at the front panel connector on the motherboard carefully, you'll see similar name/indicator as you are seeing on the above picture like Pled, Hdled etc... I hope the front panel connector has 9 pins, and remember, one should be left without any connection.
Simply you have to connect the two female Pwr-Led to the Pled+ and Pled-, and Power to Pwr and Gnd, the same sequence with hard disk led and Reset switch as Hdled+ and Hdled- and Gnd and Reset respectively.
If the front panel connectors on your motherboard has less than 9 pins, then I am sorry, I have no idea about it and I am afraid if it exists or not.
If you still have the problem, let me know.
Good luck.
Thanks for using FixYa.
Aug 01, 2010 | Computers & Internet
Pls, need to attach front panel connectors to VTE
Diagonally opposite(diagonally opposite corner) to where you connect your mouse and keyboard, there will be pins on the motherboard to connect the front panel connectors. You can identify it by names written near it like SPK or Speaker, on/off and so on. The connectors on the front panel will also have names written on them. Just match and connect them. Reset switch, Power and speaker will not be a problem connecting. But hard disk light connector will be a little tricky. you have to connect to the correct polarity. USB connectors will be near these pins and will be labled as USB5 or USB4 and so on, on the motherboard. You will be able to insert the USB connector in one direction, so connecting it is not a problem.
Aug 21, 2009 | Soyo Computers & Internet
Gateway 506GR motherboard configuration
Item Description Item Description A Rear Panel I/O Ports M Front Chassis Fan Connector B Auxiliary 12-V ATX Connector N Serial ATA Interfaces C CPU Socket O Front Panel Header D CPU Fan Header P Front USB Connector E Memory Slots Q Front USB Connector F Standby Power Indicator LED R Front Panel IEEE-1394a Connectors G Floppy Disk Drive Connector S Speaker H ATX Power Connector T PCI Express x1 Connector I Parallel ATA IDE Interface U Front Panel Audio Connector J Battery V PCI Slots K Intrusion Switch Header W Rear Chassis Fan Connector L BIOS Configuration Jumper
Aug 21, 2009 | Gateway 506GR PC Desktop
I have the same problem!!!
Diagonally opposite to where you connect your mouse and keyboard, there will be pins for connecting front panel connectors. You can identify them by the names like SPK or Speaker written near them. You just have to match the front panel connectors with that of the pins. USB pins will be near these pins and will be labled as USB5 or USB4 on the motherboard. USB front panel connector can be inserted in only one direction.
Aug 14, 2009 | IBM (49P1599) Motherboard
Describ connect front usb in msi motherboard
Diagonally opposite to where you connect you keyboard and mouse, there are pins to connect the front panel USB. You can identify it on the motherboard by the names USB5 or USB4 written on the motherboard. Just connect the front panel USB connector to either of these pins.
Jun 07, 2009 | Intel Motherboard
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
No sound from front panel of GIGABYTE GA-MA69G-S3H
Aloke,
It does mention in your manual (top of pg. 28 -notes), that in order to use the HD Front Panel Audio connector the pin configuration are different than the AC97 connections. Your current case is set up for AC97. You will have to contact Mfg. for the case click the link for Gladiator support:
http://www.a-top.com/jsp/info.jsp?number=3
You can try this, open up your control panel, look for an icon that's named Sound Effects Manager. Open it. Click speaker configuration.
This is part of Realtec's software. This is where you can setup & check both front & back ports (Audio & Mic).
If this part of Realtec did not install goto Gigabyte & down load your audio software & re-install it. (Just a suggestion).
http://www.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2554
Hope this helps. If you make the call it will be a fix.
Good luck.
Mar 14, 2008 | Computers & Internet
Intel Desktop Board D845BG (KD845BGPAK10) Motherboard Logo
67 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
