I am having problem while starting my laptop it shows message no operating system found. please help to resolve this problem
  • 32,281 Answers
This usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on May 26, 2011
My pc laptop does not start due to error 2000-03000
Try using the Last Known Good Configuration:
  • Remove any CD or DVD from your computer, power down, then power up.
  • Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration (advanced), and then press Enter.
  • If your computer has more than one operating system installed, use the arrow keys to highlight the operating system that you want to start by using Last Known Good Configuration, and then press Enter. Windows will then resume starting normally
  • Nov 13, 2013 | Dell Computers & Internet
    Operating system not found
    there is problem with your hard disk. your hard disk wire may be loose. try to remove and refix all sata wires of your hard disk. "operating system not found" message may be coming because you may have not installed any os (windows, linux or mac) in your notebook. try to install operating to system to fix this. there may also be proble with your hard disk, your hard disk may be dead. if your notebook is showing message "operating system not found" without any reason then you may have put your notebook in high magnetic field area. due to high magnetic field, sometimes hard disk's are formatted automatically.
    Apr 10, 2013 | Samsung N150 Notebook
    Getting "operating system not found" message on start up
    Restart laptop and begin pressing F8 to go to boot sequence.
    Change it to boot from CD.
    Also check if this CD is clean and works from other PC
    Jun 08, 2012 | Dell Studio 1537 Laptop
    Uliveq.dll error message
    Hi' your computer problem can be resolve but you need to ask for a person in your place to fix such thing , one way it can be resolve by using Operating system recovery tech , and in another way you may re-install a new Operating System into drive c partition only , please send me messages for some assistance . thanks
    Apr 28, 2012 | Microsoft XP Computers & Internet
    Operating sytem not found, what are the BIOS settings
    Hi.
    As the Computer is displaying an error message "Operating System not found", you may perform a BIOS reset and check if the issue is resolved.
    1) To reset the BIOS, boot the Computer to the BIOS.
    2) Once you are in the BIOS, please try pressing the F9 key.
    3) The F9 key should be the shortcut key to reset the BIOS.
    4) However, you will also have the option to reset the BIOS in any of the tabs in the BIOS main menu.
    Please try performing the above steps which I have mentioned and let me know the results.
    Hope this helps.
    Please feel free to contact for further information and assistance.
    Oct 02, 2010 | Twinhead SlimNote N12PI Notebook PC
    OPERATING SYSTEM NOT FOUND
    On my Windows 7 laptop, I have got "Operating System not found" error, to fix problem, Windows Boot Genius helped me finally!
    May 31, 2010 | Everex StepNote LM7WE Notebook
    insert system disks and re-install everything again.
    Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Operating system not found on my laptop
    ok i have had this problem.. (my computer would show the loading screen with all of the commands at the bottom. after this it would not boot up, but show a message on a black screen saying "operating system not found")
    I completly tore down the laptop and making sure i had no issues with anything. so here is what i did that is simple and ended up solving the issues 3 times in a row.
    1. take the cover off for the hard drive on the bottom of the laptop ( shows 3 very small disks beside each screw)
    2. grab the clear strip that is on the hard drive and pull out the hard drive. ( blow out where it connects on the right side if dirty)
    3. Reconnect the hard drive this will reset it.
    4. Make sure to change back the processes to defaults when the computer starts back up.. If you fail to do so you will have to repeat the process each time you turn off the computer.
    (This will only work if you messed up some settings while having the computer on, and not if you have faulty parts.)
    for me i ctrl alt deleted and accidentally ended some important processes..
    any other issues just email me at Bostelman@hotmail.com i will try to help you out. =D
    Apr 03, 2008 | Compaq Presario 1692 Notebook
    Operating system not found, hard disk not found message showing in IBMT20
    On my ThinkPad Notebook Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
    Dec 26, 2007 | IBM ThinkPad T20 2647 Notebook
    I don't have program to install the printer
    My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to   need of program to connect your Printer to Laptop . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
    I have made a lot of search and found a web link for you where you can download a Driver (program or software) that helps your Printer to work with laptop. To resolve the issue you need to download the driver for your Printer with respect to operatingg system
    Here is the below link:
    http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=25723&prodoid=36478885&infoType=Downloads&platform=All
    Open the web link, and download a driver that is suitable for your Operating system.
    This should resolve the issue for you.
    if you need any further help please let me know, you can mail me at thumuvikram@rediffmail.com I'll be glad to help you.
    Bye....
    Oct 27, 2007 | Epson Stylus CX6400 All-In-One InkJet...
    Computers & Internet Logo
    David Payne
    David Payne
