Question about Tally T2250 Matrix Printer
Can we connect the printer with windows 7 - Tally T2250 Matrix Printer
    Sergeant:
    Champion:
  • 218 Answers
I have had a search around for you, and it seams this should be ok, you can download windows 7 drivers for this unit from here. http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=45&Itemid=48&lang=en
Posted on May 26, 2011
Bizhub 350 windows 7
After you connect printer in network just set up DHCP in your printer and from windows 7 (Devices and Printers, Add new networked printer) and job is done because windows 7 will recognize printer and install appropriate drivers.
If you have problem with that uou can set up Static IP Adress in printer and search by that IP, also you can download drivers and software for that printer from this link:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=867
Feb 09, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Since upgrading to windows 7 the canon mf8180 printer is working but I can no longer use the USB connected scanner.
The Canon 8180 will work with Windows 7 32 bit operating systems only. Their latest ToolBox drivers will also get the USB connected scanner to function. 64 bit Windows 7 users are simply out of luck as the printer is not compatible. Drivers are on Canon's site and easy to access.
Dec 29, 2010 | Canon imageCLASS MF8180C All-In-One Laser...
Running Windows Emulator on a Mac (Virtual Box) trying to connect the Windows to the computer trash the printer to Windows Emulator and the printer icon is showing offline has 10.6 and uses Windows 7
Base from the description of your problem , it seems that you're using a Virtual machine running windows 7 from your MAC, In order for us to provide you the p[roper trouble shooting for this one, can you please provide us some details is the printer connected directly to your computer via USB or its connected on your network or shared by another computer? If its connected via USB try right click on the printer from printers and faxes windows from control panel and check if you have use printer offline.
This problem can be a software related problem, so if you haven't run the the setup disc for the printer yet while using the virtual Windows 7 do it right now to configure the printer properly.
Jul 08, 2010 | Computers & Internet
I just got a new pc with windows 7, could I connect my J4580 and my J3680?
If you are planning on installing both printers to this windows 7 PC, then yes, you can connect them. What you need to do first is install the driver, compatible for windows 7, for both these printers before connecting them.
May 02, 2010 | HP J3680 Officejet All In One Printer
Don't know how to connect printer to Win7 laptop
Hi there
You can not install any CD disk if you have Windows 7 then you are going to have to find the right software driver for this, there is not a lot of driver been made for the windows 7 printers yet.
They are still seling the printers with the XP drivers CD whitch is not any good for the new win 7 or Vista.
Mar 02, 2010 | Lexmark X2250 All-In-One InkJet Printer
Can't connect printer.
Hi, It seems that the you might have upgraded your computer to Windows 7 and you are not able to get your printer work. In this case you need to download printer's driver for the operating system that you are using that is Windows 7 64-bit. Download the driver from: http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX5000-all-in-one-printer/Drivers-Support
Once downloaded, install the printer using the new obtained driver. Hope the new driver would work on your computer. Moreover, you may change the USB port to which the printer is connected, meaning unplug the printer from the computer and re-connect it to different USB port of your computer and try to install printer.
Cheers!
Mar 02, 2010 | Microsoft Windows 7 Ultimate for PC
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
Is the Canon S600 printer compatibl with Windows 7?
Have you tried to connect the printer?
If so, did Windows 7 recognize it, and load the correct device-drivers?
If not, access the manufacturer's web-site:
http://www.usa.canon.com/opd/controller?act=OPDSupportWindows7Act
Select "Printers".
Select "S" series.
Is your printer listed among those that are supported by Windows 7?
Nov 19, 2009 | Canon BJC S600 InkJet Printer
Tally T2250 Matrix Printer Logo
56 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
