Question about Homelite Garden
I need a Clutch Hub for HHT-2660 can you help?
    President:
  • 1,216 Answers
Click here
You may need to use the catalog or manual to find part no.
Posted on May 26, 2011
HHT-2660 Roto choke Cover missing
Contact homelite online or by phone!
Jan 24, 2013 | Garden
Im trying to replace the ac clutch on an 04 mustang. i have the clip off but the clutch won't slide off. help please
Clutch and Clutch Field Coil adobe.gif Printable View (235 KB)
Special Tool(s) st1260a.jpg 2-Jaw Puller
205-D026 (D80L-1002-L) or equivalent st1232a.jpg Installer, A/C Compressor Coil
412-065 (T89P-19623-EH) st1235a.jpg Holding Fixture, Compressor Clutch (3.8L vehicles)
412-098 (T94P-19703-AH) st2584a.jpg Holding Fixture, Compressor Clutch (4.6L vehicles)
412-103 (T95L-19703-AH) st1220a.jpg Remover, Differential Bearing
205-116 (T77F-4220-B1) st1234a.jpg Installer, A/C Compressor Field Coil
412-078 (T91L-19623-CH) st1233a.jpg Remover, A/C Compressor Field Coil
412-067 (T89P-19623-FH) Removal
  1. Remove the A/C compressor (19703). For additional information, refer to Air Conditioning (A/C) Compressor - 3.8L or Air Conditioning (A/C) Compressor - 4.6L in this section.
  1. Remove the bolt.
    1. Hold the A/C disc and hub assembly (19D786) with the special tool.
    1. Remove the bolt.
  1. Remove the A/C disc and hub assembly and the A/C clutch hub spacer (19D648).
    1. Thread an 8 x 1.25 mm bolt into the A/C clutch to force it from the compressor shaft.
    1. Lift the A/C disc and hub assembly and the A/C clutch hub spacer from the compressor shaft.
  1. Remove the pulley snap ring.
  1. Remove the A/C clutch pulley (2E884).
  1. ani_caut.gif CAUTION: Do not use air tools. The A/C clutch field coil (19D798) can be easily damaged.
    Remove the A/C clutch field coil.
    1. Note the location of the A/C clutch field coil electrical connector.
    1. Install the special tool on the nose opening of the A/C compressor.
    1. Install the special tool.
    1. Remove the A/C clutch field coil.
Installation
  1. NOTE: If installing a new A/C compressor, the A/C clutch components should be reused unless obvious signs of damage are found. If excessive grooving is found, a new A/C clutch disc and hub and A/C compressor pulley must be installed together. Otherwise, each component can be installed individually where needed.
    Visually inspect the A/C clutch disc and hub, A/C compressor pulley and A/C clutch field coil for damage.
    • Inspect for physical damage, including cracked or melted components or discoloration due to excessive heat.
    • Inspect for excessive wear, including grooving in the A/C clutch disc and hub or A/C compressor pulley that is more than fingernail depth.
    • Inspect for roughness in the A/C compressor pulley bearing.
  1. Clean the A/C disc and field coil and pulley mounting surfaces.
  1. ani_caut.gif CAUTION: Do not use air tools. The A/C clutch field coil can be easily damaged.
    Install the A/C clutch field coil.
    1. Place the A/C clutch field coil on the A/C compressor with the A/C clutch field coil electrical connector correctly positioned.
    1. Using the special tools, install the A/C field coil.
  1. NOTE: The A/C clutch pulley is a tight fit on the A/C compressor head. It must be correctly aligned during installation.
    Install the A/C clutch pulley.
  1. Install the pulley snap ring with the bevel side out.
  1. Place one nominal thickness A/C clutch hub spacer inside the clutch hub spline opening.
  1. Install the A/C clutch.
  1. Using the special tool, install the A/C disc and hub assembly retaining bolt.
  1. Measure and adjust the clutch air gap by removing or adding A/C clutch hub spacers.
  1. Install the A/C compressor. For additional information, refer to Air Conditioning (A/C) Compressor - 3.8L or Air Conditioning (A/C) Compressor - 4.6L in this section.
hope this helps
Aug 13, 2011 | 2004 Ford Mustang
When I install clutch basket hub on my 1978 superglide 1200cc, I torque the nut to 50-60 ft lbs. Transmission will not turn. Seems to be in a bind. Loosened nut, transmission frees up. The manual shows no...
The inner clutch hub fits onto the tapered mainshaft of the transmission. If I understand you correctly, you are saying that when you put the inner hub on and torque the nut, it locks up and will not turn. The mainshaft has a woodruf key in it that goes into a slot in the in hub. If this key is pushed out when installing the clutch, it will become trapped between the hub and the inner primary housing locking the clutch assembly up. Sometimes getting the inner hub on without knocking this key out can be a daunting task for someone that is new at it. Take the hub back off, put the key in the mainshaft using a thick grease or something. Look into the hole in the inner hub as you install it and make sure the key is aligned with the slot.
Good Luck
Steve
Jul 21, 2011 | Harley Davidson FXD Dyna Super Glide...
How to upload files to a mc9090 scanner from a PC
We use a HHT base station that is connected via USB and then use Microsoft ActiveSync software to connect. Once connected you can explore the HHT from the PC and drag and drop to the HHT.
http://download.cnet.com/Microsoft-ActiveSync/3000-2094_4-10031823.html
Jan 21, 2011 | Symbol MC9090 Barcode Scanner
I have a Homelite hedge trimmer model HHT-2660. The scissor action of my blades is not functioning and taking the drive box apart I find the centrifugally driven 'cup' has broken away from the spindle...
Hi Leguer54,
I have the same fault with my hedge trimmer, I notice you posted this over a year ago, did you have any success getting yours fixed?
Thanks,
Rob.
Mar 13, 2010 | Homelite Garden
I want to buy a new handle for my homelite hedge cutter S/N 0706009769 model hht 2660 i have broken the holding handle and need to replace it
Good Day, mate. The best I can see is contacting homelite at www.homelitepower.co.uk. They have contact information on this page, however they do not show IPL(ilustrated parts list) and I am not sure the same information would be relavent to units here in the states.
HTH
Dec 12, 2009 | Garden
Can you tell me the difference between the Honeywell Tower Air Purifier HHT-081 and HHT-090? From what I find, they seem identical.
I am 99.9% sure that you are simply looking at this year vs. last year models. There are absoutly no significant changes. I will verify on Mondayas I know the engineer at Honeywell that works on this particular product!
Jan 29, 2009 | Honeywell HHT-090 Air Purifier
Garden Logo
125 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
