Question about RCA D52W19 52" Rear Projection Television
RCA D56 W20B
Like the other questions on ... the light comes n and then goes out ... can click to turn on 3 times and then it wil not show the green light for a few seconds ... then can repeat, with teh same results ... will not show anything and shuts right off. was wokring perfectly and shut off ... then this is how it has been. thanks, jeff
  • justnnss Oct 13, 2008
    thanks for the part numbers it helped greatly in identifying the hot as there is about 5 things on aluminum heat sinks. Here is a general location of the H.O.T. the board should look like this shape for a D52GW12 RCA or GE
    | |O<-----------|------ The H.O.T. should be about here on a big aluminum
    | | heatsink with paste behind it
    | |O| <-------|------ The flyback should be here
    |_________|
Ok the shape for the board was changed when i submitted it but the locations for the flyback and the H.O.T. should be the same as you open the case and look in on the board its behind the flyback to the left on a aluminum heatsink the number on the hot should be c5588 about 3/4 inch by 1 inch rectangle with a hole in the top held on the aluminum by a metal clip the part# is behind the clip mine was made by toshiba not sure if all are thanks again to slinteriors for the part numbers especially the hot
Posted on Oct 13, 2008
  • RCA Master
  • 8,617 Answers
Thats the classic symptom of a defective flyback. Its a easy inexspensive repair. change the flyback and the HOT transistor. You can get the new replacemnet flyback and HOT transistor at the following lkink with free tech support to explain step by step instructions to replace both parts. you need flyback 259296 and the HOT is 2SC5588.
Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 17, 2008
Tv wont come on
first of all you may unplug about 2 hours and try again as symptom shows some internal overheating or power failure going on
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
RCA light comes on and then goes off. Tv doesn't turn on
replace CP150 and CP114 you can get them at the following link they also have the ITC222 service manual which is listed under Thomson as Thomson makes your TV for RCA. The Capacitors are listed under the RCA parts and they do send instructions with pictures of where the capacitors are located as well as how to remove the board.
May 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Come on and goes off
3 bad capacitors located in front of deflection board cp150 cp111 cp114 they are green with gold writing on them if cp150 is bubbled up on top it is bad. 2200uf 16v. so replace all 3 capacitors.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 56
If the green light comes on and goes off 3 times and then goes off for good you have a problem that will require troubleshooting by a qualified tech and there are several things that cause this unit to go into shut down. None of these issues can be corrected easily.
Apr 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
