Question about Toshiba Satellite M45-S351 Notebook
I accidentaly destroyed my volume wheel while on low sound volume. how to put the volume back to high.
Hello!
What operating system?
There should be a volume control icon in your system tray (if it is windows).
If there isn't go to Control Panel-> Audio and there you will find your sound card properties.
Posted on May 26, 2011
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instructions
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
3 Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
Dec 10, 2011 | Apple iPod nano
4 wheel drive is binding/popping - 95 YJ Wrangler
You likely did damage the t case internally. You may be able to find a replacement in a scrapyard far cheaper than rebuild parts will cost, and, it then becomes just an r&r job. You may want to keep the old unit (if there isn't a high core charge) and at your leisure you can take it apart and rebuild it, then, re-sell the scrapyard one if you don't need it. I'd also definitely make sure you haven't broken a tooth on the ring and pinion in the front diff before going further with anything though.
Remember...when changing differentials you MUST match the exact gear ratio front and rear or you will destroy the transfer case.
Jan 21, 2010 | 1992 Jeep Wrangler
My ringing volume is very low i have tried advanced profiles and put all setting on high however its still very low i can hardly hear it.
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
Oct 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
I put my 2000 escalade in 4 wheel low last night; and now I cannot get it switched back to 2 wheel high. I will not go above 50 miles an hour when I drive it. When I press the 2 wheel high button it...
start truck leave in park press 2 wheel high button put truck in drive move truck,check for being in 2 wheel high, if still in 4 wheel low have switch and shift solenoid checked
May 17, 2009 | 2007 Cadillac Escalade Two-Wheel Drive
4 wheel low works but 4 wheel high does not.
sounds like the encoder on the side of the trans on the drivers side
Nov 24, 2008 | 1999 GMC Jimmy
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Toshiba Satellite M45-S351 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
