I just installed another video card into my computer and now the screen won't allow me to acess the start as the thyme is to large. How can I fix this problem?
  • 20 Answers
On the monitor, you might be able to adjust the height from the menu or a knob in older screens. You could try right-click in the middle of the desktop, go properties and chaneg the resolution to better suit the monitor. My guess is that you have not got the right driver loaded and therefore the resolution is like 640x480 instead of somewhere up around 1024x768. You can use the "Windows key" on your keyboard, looks like a flag symbol to get at start options.
Posted on Aug 16, 2008
6ya staff
SOURCE:
My laptop does not complete the whole screen, the screen is half, i have installed drivers but it has persisted
About Graphics and Video Card Drivers: Graphics and video Card Drivers serve as an interpreter between your Windows operating system and the Graphics and Video Card. In other words, these Drivers allow Windows to communicate with the Graphics and Video Card installed on your computer.
Most of the Graphics and Video Card Driver errors occur when the required Driver is missing, corrupt, or outdated.
Common Graphics and Video Card Driver problems: In case of a Graphics and Video Card Driver related error, your operating system will not be able to access or make best use of the functionality of your graphics or video card.
Below are the four most common Driver error codes and their meaning:
Error 1 - Reinstall the drivers for this device. (Code 18)
Meaning - The required driver is configured incorrectly or outdated.
Error 2 - This device is not configured correctly. (Code 1)
Meaning - The required driver is configured incorrectly or is missing.
Error 3 - The drivers for this device are not installed. (Code 28)
Meaning - The required driver is not installed on your computer.
Error 4 - This device cannot start. (Code 10)
Meaning - Usually, this error means that the required driver is outdated.
How do I fix Graphics and Video Card Driver problems?
Roll back to the previously installed Driver
Device Manager, an inbuilt utility in Windows, allows you to troubleshoot common driver-related errors. For instance, you may sometimes start experiencing driver related problems after you have updated it. To resolve the issue, you can roll back to a previously installed driver. To do this in Windows 7/Vista, perform the following steps:
  1. - Open the Control Panel window and double-click Device Manager
  2. - Double-click Display Adapters to view all devices under it
  3. - Double-click the device that is causing the problem
  4. - Click the Driver tab
  5. - Click the Roll Back Driver button and follow the onscreen instructions
Scan your computer using a Driver Update Tool
While Windows does provide an interface through which users can fix driver-related errors, the fact is that all driver-related issues cannot be resolved efficiently via Device Manager. Another fact is that resolving driver issues manually is a tedious affair. Also, you need to be proficient with Windows to carry out such a task.
On the other hand, driver management tools present no such problems. With just a click of the mouse, a driver management program scans your entire computer, identifies all installed hardware devices, and updates drivers for the identified devices
Dec 09, 2016 | Sony Computers & Internet
I put in a new sound card and now my computer wont start up past the lenovo screen and i need to fix it so i can work
The first thing to do is remove the sound card to see if the computer works without it. If you are still having problems starting, then you'll have to look for a different reason the computer won't start. Quite possibly you disconnected something when you installed the card. Check for that.
Nov 05, 2011 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
I bought a video card and was working fine, until i moved computer... now i have an issue.... I have a 1gig ram and shows 898 when card is removed from sys. and 1 gig when I put the video card back into...
When the card is disconnected automatically switches to on-board video which shares 128 MB of the physical memory. 1GB = 1024MB. 1024MB -128MB= 896MB. It's actually performing exactly as designed (except for the part where you say "the picture is not correct"). Are the fonts and icons too large? If they are, then you just have to install (or re-install, if ever) the drivers and software for the video card.
The video card would have most likely come in with an installation disc. Just pop it in your computer's CD or DVD drive and its autoplay function should come up automatically. THe autoplay function would provide you options for installing the drivers and applications or UNinstalling, if it's already installed.
So if it's already installed, allow the program to uninstall it first, restart the computer, if necessary, then reinstall it after it turns back on. Depending on how old the drivers are on the disc, Windows may eventually prompt you to update it. Just say yes when it does.
In the event that the drivers will not install or if there are on-screen artifacts that would not go away (especially ones that appear the moment you turn the machine on), there could be something physically wrong with the device and it may need tobe repaired or replaced
Aug 16, 2011 | HP Compaq Business Desktop dx2200 - P4 524...
When I boot up my desktop, it will show the welcome screen then my screen will go black with a large white cursor and nothing else. From there it doesn't not progress, it just remains on that screen...
Try to re install your operating system you can't troubleshoot it if your video card is working a problem like that can be troubleshoot if you can't see any video on the screen you have said that it is working at the start up to the welcome screen so it means there's nothing wrong with your video card and monitor.
Jul 06, 2011 | Computers & Internet
When I use the dvi port for my tv I cannot adjust the settings for the size of the screen. It is too large
Be sure to download the latest Nvidia drivers available here:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Once you have Nvidia's Control panel installed there are multiple setting in the program that will allow you to adjust the size of the screen that Windows will not allow you to do.
May 18, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
Just downloaded windows 7 onto desktop. screen is now too large. i have a samsung syncmaster 730b and it wont let me change the resolution to make the screen smaller
Welcome to Fixya. For you to be able to change the resolution of the screen you need to install the driver of your video card or onboard video and it will fix the problem.
Thanks for using Fixya.
Feb 21, 2011 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Black vertical lines & looks like safe mode when XP is loading
ur video card heats to much, so check if the fan in ur video card is working, if ur video card didn't have a fan try to install one
May 26, 2009 | Dell Dimension 4600 PC Desktop
I cannot upload pictures/ videos from my PNY 8GB memory stick.
The newer large capacity cards in cameras designed for smaller capacity cards seem to have trouble interfacing with our computers. The best best is to get a high speed firewire memory card reader and attach it directly to your computer.
This should allow your computer to recognize your card and also allow you quicker downloads.
May 22, 2009 | PNY 2GB Secure Digital Memory Card
My graphic destroyed
your video card has failed, you will need to reinstall your drivers or possibly even replace it.
Dec 09, 2008 | MSI (MS8936340) (64 MB) Graphic Card
Screen goes blank on Log on
Use PC wizard (search and download) this will detect all drivers needed on your computer note name and number for your video card type into search engine IE ati x300 drivers for your operating system xp vista you should be able to download correct drivers
if does not work for you please leave reply what happens
Jul 23, 2008 | HP RADEON X300 SE, (128 MB) PCI Express...
Open Questions:
Computers & Internet Logo
83 people viewed this question
Ekse
Marvin
Marvin
