Have telefunken sonata console I need the drive belt for the phonograph
Where is routing belt located on Hyundai Sonata 2001 Alternator?
I believe you are referring too the Accessory Drive Belt for the Alternator...See attached drawing
25629874-2mhejhdcommskt1vzkafo1v3-3-0.gif To Remove:
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle....saailer
Apr 05, 2015 | 2001 Hyundai Sonata
2003 hyundai sonata drive belt How do I tighten my drive belt on my hyundai sonata 2003
If this is a single seprentine belt the tension setting is automatic and is not adjustable. Why do you think it needs adjustment?
Apr 06, 2014 | Cars & Trucks
What is the layout for the phonograph drive belt on a Curtis are CD 897?
If the turntable is belt driven, the belt simply goes around the platter underneath. Once that is done, pull out a small loop of the belt away from the platter and slip it on the motor pulley. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 07, 2013 | Audio Players & Recorders
Need to find Telefunked 250 reel to reel belt for friction wheel # 339730710
Try fry's electronics, if they don't have it they should be able to cross reference or order it .
Mar 13, 2012 | Audio Players & Recorders
WHERE IS THE SERPENTINE BELT LOCATED ON A 2003 HYUNDAI SONATA
Vehicles Covered: Hyundai Sonata 2002-2004 (2.4L & 2.7L Engines)
In 2003, Hyundai produced two types of Sonata:
Available engines:
4 Cylinders 2.4L VIN "S", MFI DOHC - see Figures 1 and 3.
6 Cylinders 2.7L VIN "H", MFI DOHC - see Figures 2 and 3.
To differentiate between these types of 2003 Hyundai Sonatas, the VIN 8th digit (Engine Type) will either be "S" or "H" as in the table above.
To locate the Engine drive belt, jack up the vehicle & place it onto jack stands, then slide under the car (toss a cardboard mat down first), then, once under the car, remove the (plastic) engine splash shield. Once removed, the drive & accessory belts are easily observed.
Fig. 1 Accessory Drive Belt Routing 2.4L (4 cyl) Engine - Hyundai Sonata
The "COMPRESSOR" refers to the A/C compressor, and "GENERATOR" refers to the Alternator.
Fig. 2 Accessory Drive Belt Routing 2.7L (6 cyl) Engine - Hyundai Sonata
The Belt Routing on the Left is "With A/C", on the Right is "without A/C"
Inspection - Drivebelt and Accessory Belts
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. Worn or damaged drive belts should be replaced.
Drivebelt Removal & Installation - 2003 Sonata (2.4L and 2.7L engines)
To install:
Lower the vehicle.
Here's the best illustration I can find of the Hyundai 2.4L and 2.7L engines - the drivebelt seems to be located on the passenger side of both of these transversely mounted engines.
Fig. 3 Hyundai 2.4L and 2.7L engines - Underhood sensor locations 2002-2004 only
Glossary of Acronyms
A/C - Air Conditioning
DOHC - Dual Overhead Cam
MFI - Multi-port Fuel Injection
Dec 25, 2011 | Hyundai Motor 2003 Sonata
Timing belt replacement interval
My rule of thumb for Timing belts:
replace at 60,000 miles, and every 40,000 miles thereafter. Having said that, I often let
cars go until the timing belt starts showing signs of wear (usually every 50K - 75K miles)
But www.autozone.com (register free at www.autozone.com) is recommending for your
car driving in "severe driving conditions" (aka normal stop-start driving) that your 2000 Sonata
have:
60,000 miles - replace
90,000 miles - inspect for wear
120,000 miles - replace
150,000 miles - inspect for wear
The 155 page owners manual (I found one at the link below - you may prefer to try Hyundai)
makes no mention of the timing belt at all.
http://www.scribd.com/doc/29113477/2000-Hyundai-Sonata-Owners-Manual
Jan 02, 2011 | 2000 Hyundai Sonata
How do I replace the alternator in a 2002 hyundai sonata GLS v6?
For 2002 Hyundai Sonata 2.7L MFI DOHC 6cyl check this procedure...
Alternator - Removal
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
    Fig. Exploded view of the alternator-XG 300
  1. Before servicing the vehicle, refer to the Precautions section.
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
  6. Connect the negative battery cable.
Hope helps (remember rated this).
Jun 25, 2010 | Hyundai Motor 2002 Sonata
At what mileage do you change a timing belt in a 2007 sonata, 99% of mileage is highway.
Most car manufacturers recommend replacing timing belts after 60,000 miles. I have seen cars go 200,000 on a timing belt. But I wouldn't recommend that. Personally, that Max I would go, even if 99% of your driving is highway, is 80,000 miles. I'm not 100% sure about the sonata, but if it is front wheel drive and your replacing the timing belt, think about replacing the water pump at the same time. That is always good practice to remember.
Jun 17, 2009 | 2006 Hyundai Sonata
Timing belt
every 60,000 miles per your owner's manual
Jul 08, 2008 | Hyundai Motor 2003 Sonata
 Grubhead
Grubhead
