Question about Meiko FV 40.2 Dishwasher
Error 201 on the Meiko 40.2 undercounter. I am thinking that it is the float switch somewhere, the sump basin is filling up just fine. anybody have this problem?
    Sergeant:
    Champion:
  • 257 Answers
Check that the water hose is correctly attached and is free of "kinks" or pinching. Also check that the water supply is turned on all of the way.
Posted on May 26, 2011
  • 1 more comment
  • greenhydropo May 26, 2011
    Thanks, but it is filling up the sump basin just fine, but then gets the code error 201, so it never makes it to the wash cycle. Do you think that the water level float is failing? Is there even a water level float in this machine? Do you have an electrical schematic that I could download?
  • Ryan Pries May 26, 2011
    I think Off the top of my head it's at the front left or right, circular plastic looking thing you should be able to move it up and down by hand and hear a very slight click. I will check on the schematic.
    Here is the Schematic http://www.meiko.us/pdf/manuals/fv40.pdf
Pump continuosly runs after water is cleared out of basin
The problem is with the float switch. I have attached the manual. There is probably something keeping the float from falling back down. Check you sump basin and make sure nothing (including the power cord) is interfering with float.
Mar 24, 2014 | Hydromatic Pump Hydromatic V-A1...
I have a Meiko 40.2 undercounter dishwasher. When it begins the fill cycle, water for some reason is being supplied to both the booster tank and a small amount of water is being pushed through the ri
They are usual the same thing but it's probably the solenoid. It would be a double solenoid set up and they share components; coil, supply, etc. start there.
Nov 14, 2013 | Meiko FV 40.2 Dishwasher
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Water keeps overflowing out of the sump trey continue running
Replace water fill float valve is letting water seep buy during freeze cycle and it will not make ice due to water too warm
Jul 26, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Sump pump does not run. This happened once before and at that time the plumber got it going and said that the problem was in the switch. Now the sump basin is full and another plumber said that the pump...
rent pump & pump out water.. Then pull pump and get info off the ID tag and look for new pump or have some one check the pump to make sure it is the pump or a elec. problem.????
Oct 21, 2010 | Plumbing
Meiko dv80.2 error 201
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
Jan 30, 2009 | Meiko DV 80.2 Dishwasher
Dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
Feb 28, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
743 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Trevor Turner
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
