Question about Sharp R-1460 Microwave Oven
I've repaired my (R1460A, over the range, black) mwave several times, after having new cabinets and ceramic tile installed. I want to purchase a new one that will fit the existing wall mount and electrical penetration in cabinet. This will allow little or no replacement changes to the wall and cabinet. What model mwave(s) is recommended?
  • Sharp Master
  • 9,047 Answers
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Ask them about a "drop-in" replacement.
Posted on May 26, 2011
How to repair holes in two high gloss porcelain floor tiles
You should be able to buy a tube of ceramic filler from a hardware store which will do the job.
Aug 19, 2014 | Microwave Ovens
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
Motherboard problem in a KEMI300wbl3.After a powersurge the clock will set and the oven timer will work but the keypad resets to 0000 when I press start
There are electrolytic filter capacitors on the control board which, due to age, can weaken, causing some bizarre results.
We've repaired several of these boards successfully, upgrading the capacitors and relays at the same time. It runs $39.95 and comes with a one-year guarantee.
They're the same as the Whirlpool RM286- and RM288-type models.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded views here.
Oct 08, 2011 | KitchenAid KEMC377K Convection / Microwave...
My Kitchen Aid Microwave Model no. KHMS155LBL 0 has a broken rack support hook on one side. There are four hooks which snap into a square hole on each side of the microwave cabinet to allow the...
The part you're looking for is Whirlpool number 8204662. Several sources came up from a Google search. Here's one. I've never done business with this site, but their price was the lowest of several I looked at.
Apr 30, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kenmore Model 721.66222500 just suddenly stopped working. No light, no power, no nothing.
I just had same problem happen on a Kenmore Model 721.89940490. I took off top panel and control panel. Behind control panel is a ceramic fuse. I pullud it out and checked with my mutimeter for continunity and it is blown. Since it is 20 years old I will get a new fuse and replace it. If it works good, if not I will have to go buy a new one to put under the cabinet. My contractor that built my house in 1994 directed wired it but I\'ll spend a little extra and put a plug in the cabinet, if I have to replace it. I suspect I won\'t but there is still that possibility.
Mar 17, 2011 | Kenmore 66222 Microwave Oven
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: http://www.sanishieldproducts.com/images/el-4.jpg To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
ELIMINATE" TUB & TILE CLEANER 32 oz.
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: http://milo.com/32-oz-eliminate-shower-tub-and-tile-cleaner (out of stock!)
THIS WILL Clean it.
Kelly
Sep 10, 2010 | Microwave Ovens
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
GE microwave oven, portable, model JE160SF001, no indication of power. Panel does not light, no light inside, controls do not work. Manufactured in 2002. is it worth repairing? typical costs?
It is probably the main fuse. You'll have to remove the microwave and take it apart. There are several screws around the microwave that you'll have to remove. Just be sure when you take the scres out you know where they go back because they may or may not be same size and they have to go back exactly where they come out. Once you get the cabinet off the frame follow the power cord up until you see the fuse. It will more than likely be a ceramic fuse around 20 amps, take to maybe a lowes, home depot or radio shack and one of these will have the proper fuse.
Dec 10, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave installation under cabinet, no rear wall
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Gap between cabinet and top of microwave oven
eastlake...only if you think so. Most of these units use a submounting bracket set and then you hook your oven to it. This is a rather nasty installation...I've done several. If it's sturdy, you may just want to put in a filler piece.
Dec 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
