Question about MTX X Thunder 300XD Car Amp
It has stopped workin and the red light is flashing.Is this a code and if so how do you read it
  • 3,267 Answers
The red light is a power protection circuit designed to shut the amplifier down due to an overload or wiring problem. If the amp was playing then shut off, my guess is a problem with the speakers or the speaker wiring. Some amplifiers are only stable to a certain load. For example, most car audio speakers are 4 ohms which is the resistance placed upon your amplifier to produce a certain volume of sound. If you bridge two 4 ohm speakers together in parallel, you cut the resistance in half, thus increasing the amount of power (and volume) to your speakers. This also creates more heat and could, in effect, shut your amplifier down. I would find out how the speakers are wired to determine the resistance of the load your amplifier is pushing. Also check the grounding.
Posted on May 26, 2011
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
Red light keeps flashing on 50e47-170 how do I fix
The red flash is flashing in a pattern, should be a diagram on the furnace panel that shows trouble shooting codes.... led on means you at least have power...
Feb 20, 2015 | Home Security
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
Jun 24, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    Where is the check engine code reader at on my 89 acura ledgend?
    the plug for it should be under the dash cuz i think you need a diagnostic reader thing that plugs into it and it reads the code and shows it on the screen
    Jun 07, 2010 | 1989 Acura Legend
    Will not come on. red light flashes 4 times
    Never a good sign when you have red flashing codes
    4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
    Please rate my help++++Thanks for using FIXYA
    May 28, 2010 | Sony KDS-50A2000 50" HDTV
    E73 Error
    Error E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
    This error is also caused by a cold solder joint under the Southbridge or the Ethernet chip.Can also be one of the solder joints that lead to the GPU.
    check if you are getting any flashing red lights on your xbox 360 power up button, if you are not getting any flashing lights the probably you may try unplugging any Ethernet cable attached if you had tried connecting to Xbox Live and at that time you face this error, re-connect and check
    If you still get this problem and you see a single flashing red light on your console, please send your console for repair to MS support if it is under warranty
    Dec 24, 2009 | Microsoft Xbox 360 Console
    The printer has stopped workin only feeding threw blank paper. also both red light an green are also on sometimes flashing, i have no idea as i had this givin to me any solutions???
    Try to reset the printer counter back to zero. Read this link for some information regarding resetting the printer.
    http://tricks-collections.com/reset-epson-stylus-color-printers/
    Goodluck
    Oct 05, 2009 | Epson Stylus C46 InkJet Printer
    Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
    The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
    The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
    the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
    Press and hold the Start/Stop button while turning the dishwasher on. Release the
    Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
    Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
    Fault codes
    F00 Pots & Pans Lit
    F01 Sani Wash Lit
    F02 Normal Plus Lit
    F03 Normal Lit
    F04 Economy Lit
    F05 Rinse & Hold Lit
    F06 Pots & Pans Lit
    F07 Sani Wash Lit
    F08 Normal Plus Lit
    F09 Normal Lit Flashing
    Sep 19, 2009 | Miele G880 Dishwasher
    Panasonic PT-43LC14
    The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
    May 24, 2009 | Panasonic PT-43LC14 Television
    MTX X Thunder 300XD Car Amp Logo
    293 people viewed this question
    Top MTX Car Audio & Video Experts
    Professor_V
    Professor_V
    Matthew Spark
    Matthew Spark
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
