HI CAN YOU SAY WHERE I CAN GET A NEW REMOTE CONTROL AS THE CONTROL BUTTONS ARE RUBBER THEY HAVE WORN OUT AND WILL NOT CHANGE CHANELS OR SWITCH OFF TV THANK YOU
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
Go to the store where you buy it then tell your problem about it, or any near branch to your area to help you in your problem. Please dont forget to write in the peace of paper the brand of your tv the model no. serial no. & so forth endicate to the back label of your tv & bring your remote and then they will tell you if you need a technician, or give u a substitute of your remote for testing if its fit in your tv.
Posted on May 26, 2011
  • 62 Answers
Walmart
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
My remote will not turn my Orion on or off, but will click to desired chanels. Have changed the batteriers in the remote. mY Orion is STV2763
Hello
Your remote controls' internal touchpad has damaged or dirty. You just open it after removing the cells. Most of the remote controls are press fitted and by pressing its sides with a screwdriver will open it. Some may have screws too besides this press fit locks. Just open it by anyway without damaging its plastic cover. We have to reassemble it.
Take ot the rubber pad and you will see a printed circuit board inside it and have button type prints on it. Look for any dirt or any residue of rubber on it. Clean it with a smooth cloath soacked in rectified spirit of turpentine. Never use any strong organic solvents like petrol of so, as they will damage the rubber parts. After cleaning it; reassemble it and check. If this doesn't help, there is no other way than buying a new one. Ok.
Oct 29, 2010 | Orion Televison & Video
The buttons no longer work so it is impossible to go to the video game channel to play video games
The remote IC(CPU) is dead.Or the rubbers films help tp pust the buttons to the circuits board is worn out.Try website 1-800-Remotes Factory original.To buy an exact remote.U can tries change new batteries,take the remote aparts clean the circuits board with some rubbing alchahol
Mar 02, 2010 | Toshiba CT-847 Remote Control
I cannot change chanels or press the ok button unless i realy press hard
time to buy a new remote, your remote has been pressed hard too many times and has bent the support board out of shape. Also the switches wear and also will require extra pressure to make contact.
Please rate my help++++Thanks for using FIXYA
Nov 23, 2009 | Jeep 1:10 Remote Controled Monster Liberty...
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Televison & Video
Can only select channel 13 no other numbers respond. Channel selector only goes down, won't go up, volume control will only get lowers, will not always go down. Power switch does not respong. Have already...
Did you use your remote a lot?
Do some buttons work sometimes if you press them really hard?
If it's a double yes and you've already cleaned the remote (the rubber pad with buttons and the circuit board with contact tabs), then the buttons are most probably worn out, which means they no longer make a good contact on the circuit board tabs.
There's a repair liquid kit for remotes, i'm not sure what the brand name is or where to get it, in europe, conrad electronic was selling it some time ago, however, i make my own from benzene, rubber glue and grapphite powder.
The other solution is either to find a new rubber button pad or to get a brand new remote...
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Televison & Video
Remote such automaticaly
Looks like a jammed "channel up" (P+ , CH+ or similar) button on your remote. Try disassembling the remote and cleaning the rubber pads with some ethyl alcohol and cottonwool. Also clean the pads on the circuit board which come in contact with the buttons pressed.
If your TV set has channel up/down buttons on the front panel, it could be that one of these is jammed instead (could also be something else, i just suggested the most likely solution i could think of).
I hope this helps somehow...
regards
3rq8 (Triarcuate)
Jul 23, 2009 | RCA Universal Remote Control
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Locoal broadcast on chanel 3 and i have no switch to change output to chanel 4
First does your TV have a remote control? If it does then you have to change the output in there.If you have a VCR try using that if not then you can buy a switch at Radioshack.
Dec 18, 2008 | Logitech Harmony 785 LCD Remote Control
When i hook up dvd/ps2 i cant get it to show up on the screen
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Jan 02, 2008 | RCA F20352SF TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
