Question about AMD 4200+ Ahtlon 64 X2 Dual-Core Processor (4200ATH64X21MB)
Audio driver not install - AMD 4200+ Ahtlon 64 X2 Dual-Core Processor (4200ATH64X21MB)
  • AMD Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 26, 2011
Audio problem
I am formatted my system...all the drivers may be installed but audio driver (audio device on high definition audio bus)may be not installed. how to solve the problem. my motherboard is intel d945gcr.
Oct 04, 2009 | Intel D945GCL Motherboard
Audio driver not installed
my compaq presario v5000 laptop audio bus drive dowanloding file is not working plz send the solution
Feb 01, 2009 | Compaq Presario Notebook
AUDIO DRIVER
If you get any message when installing Conexant High Definition Audio Drivers in your Notebook, make sure that you had already installed the Microsoft Universal Audio Architecture(UAA) Drivers before installing the Audio Drivers.
Download the Microsoft UAA drivers for your Notebook available through the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32646.exe
Download and save the files in the Hard Drive of the Notebook and double click on the file to install the Drivers.
Restart the Notebook and you should be able to install the Conexant High Definition Audio Drivers which are available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
This should solve your issue.
However, if you get any errors installing the above audi Drivers, you need to try installing the Conexant AC-Link Audio Drivers as your Notebook may not be installed with Conexant High Definition Audio card :
ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32272.exe
Save the file and double click on it to install the drivers in your Notebook.
This should work...
Sep 05, 2008 | HP Compaq Presario V2000 Notebook
No audio
You must do this in order to get the sound working on the C700 series with XP, the LAN drivers can be found at driverguide.com:
This model of Presario has an audio controller that supports
the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) bus driver for high definition audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/sof...4000/sp33867.exe ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver from the above links you have
to restart the notebook and then install Conexant high definition
audio driver from the following link :
ftp://ftp.hp.com/pub/sof...4500/sp34200.exe ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Installing the audio drivers may result in an error, but continue
with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "audio device on high definition audio bus" and click update driver.
3. Select "install from a list or specific location"
4. Click next. Then select "don't search, I will choose the driver to install"
5. Click next and then select "sound, video and game controller" from the list.
6. Click next and then click have disk.
7. Click browse C:swsetupsp34200 folder and select the .inf file and click open and continue with the on screen instructions.
Aug 13, 2008 | Compaq Presario 700 470024-192 Notebook
Pl privide me audio driver for presario C785TU
You must do this in order to get the sound working on the C700 series:
Jul 27, 2008 | Dell Inspiron™ E1505 PC Notebook
Unable to install Audio driver
Have you installed the chipset drivers first?
Apr 12, 2008 | Compaq Presario 700 470024-192 Notebook
Audio drivers for LG laptop
My laptop doesn't have audio drivers and it rejects each and every audio driver that i try to install. can you please help download and install a new audio driver
Apr 03, 2008 | Computers & Internet
Compaq c733tu
Hi.
Your model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio
Architecture(UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio drivers.After installing the UAA drivers restart the notebook and then install
the audio drivers.After Audio drivers installation,U have to folllow the steps.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select "Install from a list or specific location".
4. Click Next. Then select "Don't search, I will choose the driver to install".
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp***** folder and select the .inf (wisxxxx) file and click open and Continue with the onscreen instructions.
Feb 25, 2008 | Computers & Internet
have installed XP in Compaq Presario 707TU Laptop. I have configured audio as below. Install Microsoft UAA sp31994, then install High-definition audio driver sp33443. But I get the error message "Driver Installation Failed: Could not find the MEDIA device for this driver."...
Feb 12, 2008 | HP Compaq Presario v3000z Notebook
AMD 4200+ Ahtlon 64 X2 Dual-Core Processor (4200ATH64X21MB) Logo
56 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
