Ten computers are connected in the server.... when the client tries to log on his computer it takes 30 min to log on.what will be the problem?
  • 20 Answers
Wow,... how long is a piece of string. Could be dns or wins not setup correctly, could be group policies applying, could be the network switch has a fault or the cabling that hooks them up. Is it only 1 computer, or all 10? What is the server. Windows 2000 server, 2003, Linux, ?? Tell us more about the network setup.
Posted on Aug 16, 2008
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
cant view my client in handycafe my net and router r ok last night i can view but now there gone
Mar 01, 2012 | Ates Software HandyCafe
1. My 2008 MacBook Pro rejects most cd's and dvd's, has a Intel 2.5 GHz Intel core 2 processor. 2. When I downloading or streaming movies they keep re-buffering
Solving Problems with Streaming Services
If the Server Does Not Start Up or Quits Unexpectedly:
  • Check the error log.
  • Make sure the QuickTimeStreamingServer file is in the /usr/sbin/ folder.
    You must be logged in to the server computer as Administrator (root) to see the QuickTimeStreamingServer file in the Workspace Manager.
  • Use the Mac OS X Server Setup Assistant to reconfigure the Ethernet ports.
If Media Files Do Not Stream Properly:
  • Make sure the movie file is supported by the QuickTime Streaming Server. Check the list of compatible file formats.
  • Try streaming a sample movie to see if the server can stream it. You can download a sample prehinted movie from the Apple Software Updates Web site:
    If the server streams the sample movie, the problem you're having may be with the way your movie file is prepared. Recreate the movie.
    If the sample movie doesn't stream, the problem you're having may be with the server computer or the network.
  • Try hinting the movie again with the Optimize Hints For Server option selected.
  • Check streaming server activity and if necessary, reduce the number of connections or throughput.
  • If the problem occurs on a Mac OS client computer, open the TCP/IP control panel on the client computer and make sure MacIP is not selected.
  • If the problem occurs on a client computer, make sure the user has the appropriate settings in the Streaming Proxy and Streaming Transport panels of the QuickTime Settings control panel. The administrator for the client computer's network should be able to provide the correct settings.
  • If the problem occurs for media streamed using PlaylistBroadcaster, try hinting the movies again with the RTP Payload Encoding set to QuickTime and Smooth Data Rate enabled.
  • If you are reflecting more than one live stream, make sure each stream uses a separate UDP port. Otherwise client computers will show a message with error 500. You set up ports in the relay configuration file.
If Streaming Service is Slow:
  • If you are streaming QuickTime movies, make the movies self-contained using your authoring application, and make sure hinting is optimized for streaming services.
  • Reduce the maximum number of connections or the throughput.
  • Turn off other services.
  • Place media files on other hard disks to improve server performance.
    Because QuickTime Streaming Server can use only one media folder, you need to create links from the folder you have selected in QuickTime Streaming Admin to the media files on other hard disks. To do so:
    In the Workspace Manager, press the Control key and drag the folders that contain the media from the other disks to the folder you have selected as the media folder.
Aug 04, 2011 | Computers & Internet
Hello, Trying to install this NetGear RangeMax NEXT WN311B into a Pentium III computer with a AMD chip, should be fairly simple just put SSID and Passphrase, - IT WILL NOT CONNECT! Please help
From a computer that uses an Ethernet cable to connect to the router,
access the web-server "inside" the router, and enable "logging" of events,
i.e., attempts to connect, and IP-addresses handed-out by the router to wired/wireless clients.
Then, on the computer with the RangeMax, try again to connect.
Go back to the computer connected to the web-server, and "refresh" the view of the newly-updated "log" file. What new messages are displayed?
Nov 17, 2010 | NetGear RangeMax NEXT WN311B...
I am trying to downlaod something but i need to wright a proxy sever but i don't know what a proxy sever is or how to do it?
In computer networks, a proxy server is a server (a computer system or an application program) that acts as an intermediary for requests from clients seeking resources from other servers. A client connects to the proxy server, requesting some service, such as a file, connection, web page, or other resource, available from a different server. The proxy server evaluates the request according to its filtering rules. For example, it may filter traffic by IP address or protocol. If the request is validated by the filter, the proxy provides the resource by connecting to the relevant server and requesting the service on behalf of the client. A proxy server may optionally alter the client's request or the server's response, and sometimes it may serve the request without contacting the specified server. In this case, it 'caches' responses from the remote server, and returns subsequent requests for the same content directly.
A proxy server has a large variety of potential purposes, including:
1: To keep machines behind it anonymous (mainly for security.
2: To speed up access to resources (using caching). Web proxies are commonly used to cache web pages from a web server.
3: To apply access policy to network services or content, e.g. to block undesired sites
4: To log / audit usage, i.e. to provide company employee Internet usage reporting
5: To bypass security/ parental controls
Aug 01, 2010 | Computers & Internet
I have a windows 2003 SBS Standard Edition and IP Address: also a Linksys WRV210 and the IP address I have setup a preferred DNS on all clients to The internet is not...
For that connect your router to directly to lan ports of your server.and install another ethernet lan card on server so that ports connect with switch.
Then configure your router as bridge connection then set dns as your server ip in all computers.Then you can get 100% fast internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 15, 2009 | Computers & Internet
100% internet connection but PSN won't let me login
That is very common, I too get that DNS error while attempting to log in. Im pretty sure it is just the playstation servers. For me it usually takes like 20-30 minutes until they get it running again or if your anxious to play just keep trying, sometimes it might only take 5 or 10 min. Hope this was helpfull.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Premium users are not allowed to access this server. Error???
Lets try to update your yahoo by doing so many problems will be solve, it will take few min depending in your conection.
Your rating is very important to me...
Was this helpful?
May 25, 2009 | Yahoo Mail
Win server 2003's drive c: is access to all client computer
Kindly revert for further analysis - for the points below said above - have you shared c:\ for clients ?
2.Are you using Terminal server - without security policy ? Your client directing logging in the server ?
if not any of the above please explain - ur problems in point specification.
(mail me across in case of emergency)
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
