Question about Harman Kardon Harman JBL MSC1 Monitor System Controller with RMC
Today my computer didn't recognize my MSC1, so I decided to do a FIRMWARE update to try to fix the problem, but then it got worse. Now my MSC1 won't even turn ON, Please let me know how to fix this.
How do I connect my M-Audio Projectmix I/O to my PC running Windows 7 x64 via TI Firewire card? PC is not recognizing Projectmix.
Did you change the IEEE 1394 Host Controller to a legacy driver or did you just add one? You have to change IEEE 1394 to the 1394 OHCI Compliant Host Controller, specifically.
Did "Firewire Enabler" get installed in the Start menu? If so, give it a try. Make sure to download the latest PMI/O update from M-Adio if you haven't already.
Also, the old computer might of had a different PCI card. I remember there being compatibility issues with PMI/O and Express cards. Check the card type. There might be a firmware, patch or an update to fix the issues.
If the card is incompatible, just switch out with the other (if you still have it).
If the issue still exists, try Klinke's MCU plugin. It should work if nothing else. Maybe check for ASIO Driver issues. Other than that, it would have to be hardware or bad cables.
Aug 15, 2016 | M-Audio ProjectMix I/O Control...
Ns7 freezes or auto update firmware
Joshua's answer has nothing to do with your problem.
Jan 20, 2014 | Numark Industries Numark NS7 Numark...
Behringer deq2496 displays firmware data not found / what do I do
Go to http://www.behringer.com and update new drivers and firmware. If you lack the Firmware, the system will not open or recognize the device at all. Check with their technical service and tell them to walk you through the process of installing the new firmware.
Dec 19, 2013 | Behringer Ultracurve Pro DEQ2496 Digital...
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
I think I've a failed unit. Turning it on - the USB flashes and then it remains on the logo splash screen. I have tried numerous times to factory resent - holding down the System button on power on,...
It MAY be waiting for an UPDATE of firmware via USB. In other words you may have triggered an update mode that it will not exit without sending an update. The second possibility that comes to mind is that one of the buttons or the switch behind it may be stuck which can lock up the processor. Look for a button stuck in or that feels un-normal.
Aug 23, 2011 | Lexicon MX400 FX unit (with )
I installed my new Roland SD-50 and all worked fine untill it turned off automatically (powersave mode was default). After that computer didn't find the canvas. I decided uninstall driver by hardwares...
You may have to coax it back by unplugging or even trying a different connector on the computer. It may have disabled the port due to a current spike. Using the devoce manager in the windows control panel, see if the port has been disabled. If necessary delete the device and tell it to seearch for new hardware.
Jul 17, 2011 | Cakewalk Roland SD-50 Mobile Sound Canvas
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Hello! I bought the mini strobe light a couple weeks ago and it worked fine when i tested it out a couple times. but my party is this saturday and i tried it out again today and it was running and then...
With risk that warranty will be voided, you could open it and look for problems. Most of these have a speed control so if yours does, vary that to insure it is not near the real slow end of the range.
Jun 09, 2011 | Chauvet Ch730 Mini Strobe Light Effect Dj...
Harman Kardon Harman JBL MSC1 Monitor System Controller with RMC Logo
82 people viewed this question
Top Harman Kardon Music Experts
Michial Gueffroy
Are you a Harman Kardon Music Expert? Answer questions, earn points and help others
