Question about Samsung SM943N 19" LCD Monitor
My samsung syncmaster 943nwx monitor , has freeze nearly 2.5 cms horizontal both left and right side. i am able to see the screen browze. but my horizontal width is not in full screen, both side got some freeze nearly 2.5 cms either side pls help me to solve this issue immediately thanks much
  • 4 Answers
Use your brain
Posted on May 26, 2011
Only horizontal line is displayed. if i knock the back side heavily proper display is coming.
The Samsung has an intermittent problem, the back of the set needs to be removed and main board flipped over, if you are handy with solder iron look for bad solder joints on the main board and start re-soldering the flybach pins, and the vertical section right near the flybach and any other connections that need attention.
Dec 28, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung syncmaster 914v monitor problem. right side of display is darker image. can see dots like a newspaper print or looking through a screen. when display is black it almost appears like an image is...
This is likely the LCD panel itself - you are describing a left/right image error that can be only created by the left/right division by the LCD driver wrapped around the outside of the LCD panel.
If your monitor uses a separate circuit board to drive the LCD, it could be this driver board.
Either way, it will require an LCD panel - $$$
Mar 29, 2010 | Samsung SyncMaster 914V 19" LCD Monitor
My monitor is a 943nwx syncmaster 19' it accidently fell down from a height of 1 foot after this it does not work at all What can be done about this?
Try your luck, if it's under warranty. They have 1-year on-site warranty on SyncMaster 943NWX where they ask no questions. The heat-sensitive power button failed to work in my 943NWX and was solved with no questions. It depends mate, if you are lucky.
Dec 25, 2009 | Samsung Computers & Internet
No display till 10mins of pc starting Samsung SyncMaster 943NWX
The fault maybe an inverter board fault or CCFL lamp fault.
For service, pats, and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 10, 2009 | Gateway 19" Flat Panel LCD Monitor
A problem on my screen
It happens due to two cause first one is you have any power saver, speaker or any magmatic device near your monitor(screen) and other cause is your monitor going to damage. Please do not keep any things near monitor and check it. I hope it will work fine.
Good luck.
Thank you
Sachidanand
Aug 19, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
MAC screen doesnt fill Samsung Monitor
Often there is an auto correct button on the monitor, if not them press them menu button and navigate to find horizontal size. If neither of those work you might try taking apart the monitor and reseating the video cable to the monitor.
Jun 08, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Samsung SM943N 19" LCD Monitor Logo
150 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
