Question about Argox OS-214 Label Printer
I am usinf Label view to design the prn file.And when I choose the label dr 200 as printer I can see only "true type fonts " and can not see any other fonts. If I use the true type font ,my printer makes error. How can I solve this problem ? Please help me:)
SOURCE: spits out label but cuts words off
Problem is solved by pressing the function key until "margin" comes up. Then press function key again while "margin" is selected. Use the arrow key to select the "###". Then once that is selected press the function key again. That solved the same problem I had. Good Luck :)
Posted on May 09, 2007
  • 6 Answers
SOURCE: Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Posted on Sep 25, 2008
leroyal
  • 2120 Answers
SOURCE: Need operations manual for Casio EZ label printer
http://world.casio.com/ds/download/en/manual/
Posted on Jan 02, 2009
SOURCE: can't change the font style & size on my Brother PT-65 Label make
In case you've forgotten how to change the text size, hold down 'Code' and '& Size' key to display the current setting. While still holding the Code button, push and release the '&' key to change the size.
To reset, I would try removing the batteries for a few minutes before reinstalling them.
Just two guesses.
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: wrong gap detect
what is the Gap size between two label line
if your gap size low 3mm. This gap size problem for you and cange your label.
at the same time you, install label then power off then during press feed button you must be power on printer. The printer empty label print then power off printer then you power on normally
Posted on Apr 04, 2009
I have designed a software to print visitor badges on spot for conferences but i am unable to send the print command to my Brother QL-570 Label printer ..I am not able to generate a .prn file .. please...
Welcome to FixYa.
To generate a PRN file, you need to have the printer driver installed in your computer. You should be able to see the PRN option (in some cases, it is termed as 'save to file') in the printer dialog box.
In your own software, you have to use the printers driver as well to produce a PRN file as well.
Since you are also unable to send the print command to your printer, it seems that your printer driver is not present or might have been corrupted.
Download and install the driver for your printer from >>HERE
Thank you for using FixYa, have a great day.
Jas247
Jul 24, 2011 | Brother HL-2040 Laser Printer
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
Introduction
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
Theme).
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
printer.
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
WANT PRN FILE FOR BARCODE LABEL DESIGN
HOE TO DESIGN A PRN FILE FOR ZEBRA TLP 2844
Jun 03, 2010 | SATO CX400 Thermal Label Printer
Using multiple printers on switch box. Z4M Plus and Z6M. Sometimes data is missing or printed incorrectly. Font size changes or certain text is missing. We are using Label Vision Version 4.3. It is like we...
The problem with this type of printer is that when you use true type fonts, they are downloaded as graphics. If you have a field which changes on each label there is an overflow of memory. The solution is to use internal fonts for continuously changing datas
Oct 08, 2009 | Zebra Z4Mplus Label Printer
Loading True Type fonts from C: drive with ZPL commands.
yes right, please go through ZPL2 manual for more understandings
Jul 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844, Code Page for Arabic Character Problem
Download a free "Arabic" true type font. Use Zebra Designer to print your label and use the arabic font to print any character.
Apr 16, 2009 | Zebra TLP 2844 Label Printer
BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Feb 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Argox OS-214 Label Printer Logo
233 people viewed this question
Top Argox Office Equipment & Supplies Experts
k24674
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
