Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Acer E380 - How do I change the DVD drive?
It looks like the drive is supposed to come out the front, but how do I get the front panel off?
There are 6 clips on the inside of the case that hold the front cover. You will need to remove both the left side (easy side with two hand screws) and the right side (two philips screws).
Use a flat head screwdriver to pop the clips on each side (3 on each side) and the cover will come off.
Good luck.
Posted on Sep 03, 2008
How to remove front panel to repair the front usb ports on an Acer Aspire E380 -?
The front USB connectors are usually either molded into the front case or held in via a clip or screws. Unfortunately, when they go out due to the tab within the USB port breaking, they are not easily replaced as each manufacturer creates their own proprietary connector...not the USB part but the hardware to hold the USB in place. So you will find the hardest part of this project finding the right connector or "jerry-rigging" the new one to fit.
Another alternative is to remove everything from the old case...the mainboard, all the drives and whatever else can be moved, and put it into a new case. If your current power supply is good and of a standard size, etc...you can get a used case for around $10.00 and put all the other things from the old one in it. Fortunately, this series of Acer seems to be pretty much generic so everything should fit....just make sure the "new" case has good front USB ports.
Jul 12, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
I have an Acer Aspire E380 desktop. Does it
It should not matter as long as the antenna is not surrounded by metal.
May 08, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Will an IDE DVD Burner work on my Acer Aspire E380 desktop. The hard drive is a SATA but the burner looks like an IDE and has belt cables. I need to replace my DVD burner and not sure what type of burner...
Yes, all you need is a IDE (Pata) to IDE (Sata) converter.
If you're replacing it, just make sure you get one with the correct interface, judging by what you sat SATA.
Mar 13, 2010 | Acer Aspire E380-ED422A PC Desktop
Acer aspire e380. does anyone know the dvd drive speed???
When you load your DVD software, there should be a menu option that will query the drive and report the maximum speed for both DVD and CDROM reads and writes.
Jan 07, 2010 | Acer Aspire E380 - Athlon 64 X2 4200+ 2.2...
Acer Aspire E380 won't start. When powering on the cpu fan runs at high speed but nothing else operates. Disc drive etc.
plug out the power cable connected in your CPU and replug it again still its not working you need to change the power cable
Dec 19, 2009 | Acer Aspire E380 ASE380-UD500A PC Desktop
The sound of my computers audio is strange. The computer is Acer Aspire E380 with Realtek High Definition sound card. Can anybody help me?
Try this, double click on the realtek HD audio icon on the system tray (orange speaker), click the effects tab, check if there's an active sound effect, change the effect to none, this should return the audio back to normal. Otherwise, either there's a problem with the speaker or on-board sound card.
Sep 26, 2009 | Acer Aspire E380 Desktop - AMD Athlon 64...
Taking front panel of an acer aspire e380
please try with acer for spare they might help u with this because the design of model r pc will be different thats better to call acer
Feb 26, 2008 | Computers & Internet
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
593 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
