Question about Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V Automatic Submersible Sump Pump, 8' Power Cord
When i **** air through the air breather tube the pump starts pumping water. I pull the pump out of the water put it back in the water and it will not start automaticallly. I **** on the tube and it starts pumping again. I tried shop vacuming the air breather tube but it still does not work. It is brand new and the first time I used it.Please reply as I have to manually start the pump every hour so i do not overflow my sump pump hole and it is hard to get any sleep.
  • bkmayi May 26, 2011
    The hole is 7 inches. I have another little giant working in a 3 inch hole right now. i put it in a pail with water 8 inches over the whole little giant and it still wont work. i took it apart and the switch seems real stiff so i do not believe water can put enough pressure to close it. I am going to try wd 40 on it.
  • Little Giant Master
  • 43,501 Answers
That pump is set to start when you get between 7 and 10 inches of water in the hole and shut off between 1 and 4 inches...
How deep is your hole???
You may have to try and make the hole deeper....there is also no way to adjust them...
Personally I will not install any pump with a pressure activated switch... too many problems...I only install pumps with a vertical float switch, they seem to work the best...
heatman101
Posted on May 26, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 26, 2011
    You are probably right and the switch is too stiff to activate...and... they are all a bit different. That's why I like the vertical floats... they always start and stop the same... the only problem with them is that they can get a stick or other debris under them and hold them on...
    Usually I place them in a bucket with holes drilled in it to keep the debris from the pump...
How to Patch a Bicycle Tube?
buy a new tube.
Pull out tube
Pump air in to it
put under water
notice were are leaks from
using a bicycle patch kit
sand tyre around hole
glue patch over hole
wait for glue to set
check no nails, glass embedded in tyre first before you
put tube back inside tyre
put tyre back on wheel
https://www.youtube.com/watch?v=x5x7GIc0e6g
https://www.youtube.com/watch?v=WG7Y1eSDsNA
Oct 20, 2016 | Cycling
Why 1992harley pumps oil when cranking over to star
Check your oil tank level. If it is empty or very low, the oil has seeped by the oil pump check valve and has filled the engine cases with oil. I assume the oil is coming out the air cleaner breather tube? If so, add a quart or so to the oil tank, run the breather hose into a can or bottle, and start it up. Oil will flow out the breather until the cases have been purged. When it stops pumping out refill the oil tank to the proper level. This can happen when the bike has been sitting for a few months or more.
Mar 12, 2015 | 1993 Harley Davidson FLSTF Fat boy
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
How to remove air filter on 2001 fxst
Remove the screw and air cleaner cover, remove the three TORX screws and the bracket from the filter element, gently pull both rubber breather tubes from the back of the element, remove the filter element and gasket, replace the filter element if damaged or if filter media cannot be adequately cleaned, gently pull the breather tubes from the breather bolts on the backplate, clean the filter element by washing the paper/wire mesh air filter element and the breather tubes in lukewarm water with a mild detergent, do not strike the filter element on a hard surface to dislodge dirt, allow the filter to either air dry or blow it dry from the inside with low pressure air. Do not use air cleaner filter oil on the Harley-Davidson paper/wire mesh air filter element. c. Hold the filter element up to a strong light source and if light is uniformly visible through the element, it is sufficiently clean.
May 09, 2014 | Harley Davidson FXST Softail Standard...
I have an 89 f 250 with dual tanks. Front tank has never worked since I bought it. Recently the truck started stalling out ( No fuel to the injectors) I replaced the fuel pump relay. Nothing. I pulled the...
Check tanks for balance tube between tanks If the air pressure is not allowed to equalise between tanks then the vacuum formed will not allow fuel to flow to the pump. Breathers on both tanks are a start.
Apr 07, 2013 | 1989 Ford F 150
Engine rpm stays high when shifting gears
may be the air pump,having water in it .this does not mean that the pump it self is bad but a breather tube or something smaller.had same problem on 5spd saturn
Dec 19, 2012 | 1997 Ford Ranger SuperCab
77 shovelhead w joe hunt mag and s&s oil pump everything is great except after about 20 mins of riding oil start coming out of gasket all around cam cover and mag assembly dont know what would cause...
There ae a number of things it could be. What it sounds like to me is that the oil is not being pumped back into the oil tank and is collecting in the cam chest. It should be blowing out of your crankcase breather tube as well if your crankcase breather tube is open. Behind the oil pump, there are three holes. One is behind and above the oil pump. This is where the breather tube from your oil tank and the primary comes into the engine. The hole directly behind the oil pump in the middle is the oil return line from the very back end of the primary where the oil from the primary is recirculated back into the engine. The bottom hole behind the oil pump is the crankcase breather. It should have a hose that runs back around behind the transmission and just dead ends in a bracket pointed towards the final drive chain. This hose should be open to vent the crankcase pressure. Have you checked to see if oil is being pumped back into the oil tank? If not, the scavenge gears of the oil pump may not be pumping the oil out of the engine and back to the tank. If this is the problem, you may not have the drive key properly installed in the scavenge gears of the oil pump. Still, oil should be pouring out of the crankcase breather hole. But, this is what it sounds like it's doing to me. The oil is building up in the cam chest for some reason.
Good Luck
steve
Sep 06, 2011 | Harley Davidson FXDWGI Dyna Wide Glide...
What could cause excessive oil pressure in the oil tank of an 1988 evo, plug blows out of oil tank, when loose plug is left in oil weeps from tank and caskets have started to leak. I have changed the...
Check your crankcase breather hose. On the '88 model, it originally came from way down low behing the oil pump up to the backside of the air filter plate. If the bike was purchased used, the original owner may have rerouted the hose in order to avoid oil getting into the air filter. Find the crankcase breather hose and check to see if it has been plugged by something or has become crimped.
I'm confused by the term "breather valve". I don't know of a breather valve on the engine. If you mean the "breather gear" in the cam chest, this is good as the originals were made of plastic. These would break a tooth off the gear and quit turning. Usually the broken tooth would lock up the oil pump and indicate a problem in the area. However I have seen on occasions that the oil pump was not locked up by the broken tooth and the engine would build up too much pressure inside. I've seen the pushrod tubes start to leak because of this. If I have misunderstood and you have not pulled the "nosecone" on your engine to check the breather gear, that could be your problem as well.
But, do not pull the nose cone unless you know what you're doing. I've fixed several bikes because the owner went to check the breather gear and didn't know what all was involved in doing this. The nosecone would come off about a quarter inch and hang up, would come the rest of the way off and wouldn't go back on either. If you need specific instructions on how to take the "nosecone" off, repost and I'll tell you how to do it. You'll need a pair of tappet block pins to do the job.
Good Luck
Steve
Nov 16, 2010 | Harley Davidson FXST - FXSTI Softail...
How long does it take to change a water pump in a 2002 SL Saturn
Hi. Normal installation would take 45 to 1 hour depends on your expertise. Here's the procedure on how to replace the power pump.
  • TOOLS REQUIRED
  • J-43651 Water Pump Sprocket Holding Tool
REMOVAL
  1. Disconnect negative battery cable.
  2. Remove air inlet tube and air cleaner assembly. Refer to "Air Cleaner Assembly Removal".
  3. Drain coolant.
  1. Remove exhaust manifold heat shield. IMPORTANT: Twist water feed pipe while pulling to remove it from water pump.
  1. Remove thermostat and water feed assembly bolts.
  1. Remove water pump sprocket access plate from front cover.
  1. Install J-43651 water pump sprocket holding tool. IMPORTANT: Be sure to remove retaining bolt that is accessed from front of engine block.
  1. Remove water pump retaining bolts.
  2. Remove water pump assembly.
INSTALLATION
NOTICE: Prior to installing the water pump read the entire procedure. Pay special attention to avoid part damage and to ensure proper sealing.
  1. Install water pump assembly.
  2. Install water pump bolts. Initially finger tighten bolts
  • Torque: 25 Nm (18 ft. lbs.)
  1. Install the water feed tube.
  2. Lubricate the feed tube O-ring with silicone gel lubricant.
  3. Install water feed tube by twisting and pushing toward water pump. Take care not to tear or damage the O-ring.
  4. Install thermostat housing to block bolts.
  • Torque: 10 Nm (89 inch lbs.)
  1. Install exhaust manifold heat shield.
  1. Install air cleaner assembly and air inlet tube. Refer to "Air Cleaner Assembly Installation".
  2. Connect negative battery cable.
  3. Add coolant.
Aug 27, 2010 | Saturn LS Cars & Trucks
Older mecury wont pump water
when you install a new pump it will "cavitate" (pump air) unless you pack it with petroleum jelly.
Jul 29, 2010 | Boating
Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V Automatic Submersible Sump Pump, 8'  Power Cord  Logo
191 people viewed this question
Top Little Giant Plumbing Experts
JOHN LAPIER
Mack Baxter
Tom Chichester
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
