Question about Samsung Televison & Video
I have a samsung dlp hlt5076sx/xaa and tv normally works fine till I watch tv for more than two hours then it will shut off and the temp light will start to flash I recently replaced the bulb and now this any help out there?
  • 373 Answers
You may have to blow out the dust (if any) inside the set (a common reason). Or if the picture scrambles up any before going out you may need to replace the color wheel. And it is possible the fan could be breaking down or slowing down and causing overheating which will make the thermal switch to cut the set off.
Posted on May 26, 2011
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung hl-s5087w.... Tv is 4.5 years old, and is about 200 hours into its 3rd bulb. Yesterday, very similar to when the bulbs burnt out, it shut off. I thought that it may be getting too hot, so after it...
Above the light is a temp sensor with a blue and white wire plug. This sensor is the problem for all these shut downs in my opinion. Pull out plug and jump it with a wire or paper clip bypassing sensor. Tv should work now!!!!
Apr 23, 2011 | Samsung HL-S5087W DLP TV
I have three blinking lights one my samsung dlp HLT5076SX/XAA after replacing the ballast,color wheel and the lamp. any idea on what this problem could be???
it could be the fan also make sure you have correct parts for the set, make sure lamp has not been touched. door closed completely
Jan 20, 2011 | Televison & Video
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung HLT5076SX XAA turned itself off. Two
If you do not hear the color wheel start to spin inside of light engine this may have failed also check to make sure fans are working and safety switch is making contact
Mar 05, 2010 | Samsung HL-T5076S 50 in. TV
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
My samsung DLP hls5687wx xaa shuts off by itself. How do I fix it?
The lamp ballast or Color wheel might be the problem. We have experienced both issues with the tv shutting down. Also check the hours on your lamp as it might be getting old.
Jul 07, 2009 | Samsung 56" Slim-Depth LED DLP HDTV
Televison & Video Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
