Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
I would like to see a waterline diagram for GE profile performance model # tpx24sp ba bs
  • 833 Answers
SOURCE: ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Posted on Jan 24, 2008
Maytag317
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
aasc
  • 1606 Answers
SOURCE: where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Posted on Sep 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
SOURCE: My GE Profile PS123SGPA BS side by side keeps
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Posted on Feb 21, 2010
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
How to repair broken water line at water pump
There are repair kits available, Contact your local GE parts retailer and give them your model info.
Mar 10, 2012 | GE Refrigerators
GE Profile Performance TPX24SP No ice. Water to fridge but does not seem to get to icemaker. It cycles and I can hear the solinoid but no water flow. Maybe the water line is frozen? How do I...
I had the same problem. The the repair tech found two broken 5/16" plastic tubings on the output side of the ice maker and door water dispenser solenoids. These are located on the Bracket and Valve Assly. where the main water connection is on the rear of the refrigerator behind the cardboard grill. The tubing is placed right next to the hot compressor so they crack over time.
Sep 18, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile gas oven will not ignite. The
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
May 13, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The water does not dispense on our ge model tbx25pr frig. i would like to have a wiring diagram to troble shoot the cause
no diagram needed, possibilities: low water pressure coming to refrige...(have hollow cubes?) 2.cracked waterline behind rear access panel,3 clogged filter 4. the waterline is frozen w/in freezer door....if no help ge will send a serviceman over w/fancy laptop and invoice for a load of money
Mar 03, 2010 | GE Refrigerators
Where is the thermostat on a GE profile refrigerator Side-by-Side
Sep 12, 2009 | GE Refrigerators
Ice maker and water dispensor not working on GE profile model 26...could it just be a frozen line?
yes.........unless the waterline from the house hookup ie--saddlevalve is plugged follow the waterline from where it hooksup turn to close all the way!!! then turn it back on see what that does for you because if the saddlevalve is hooked on the bottom of the waterline it could have gotten plugged over time
Aug 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
106 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
