Potterton EP4001 timer fault C1, what does it mean?
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Posted on Jul 03, 2008
SOURCE: My Potterton EP6002 timer has its HW light
How do you remove the front cover of a Potterton EP6002/7 timer
Posted on Mar 22, 2010
Have a aeg oko lavamat 88730 update runs for short time then shows C1 what is wrong with it and how do I fix it and how much
C1 is fault in prewash cycle and means no water inlet.
Could be: vaIve does not open or interruption, flow rate to low.
So, I suggest to check an following parts: water inlet, clean sieve, inlet valve, pressure sensor, wiring.
Dado
Jun 12, 2016 | AEG Washing Machines
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
My potterton 60 e has stopped working after rain has got onto the boiler
That's a shame. As the combustion area is room sealed none of the water should have gone in there. Most likely the water will have short circuited connections at the base of the boiler, and blown the 3A fuse for the entire heating system.
So, do you have any signs of life on the programmer/timer? Does it light up, tick, or have any lights (lit) on it? If not then find and CHECK the 3A mains fuse....and I can't tell you where that is, but usually it's in the airing cupboard, by the timer, or near the boiler.
If that fuse is OK then you will need to hire a gas fitter with electrical/fault finding experience to look closer.
Aug 14, 2014 | Heating & Cooling
Install guide for ep6002 programmer
It would probably be best to contact Potterton or Baxi Potterton
at the email address: enquiries@potterton.co.uk
www.potterton.co.uk
Potterton Myson, send all enquiries to Baxi Potterton
I only found one PDF file online and it was a general book that showed how to wire most of the wire systems and controllers.
http://atibook.com/dl/en/Others/Tutrial/9780750664363_domestic_central_heating_wiring_systems_and_controls.pdf
May 23, 2014 | Garden
I just moved ina flat with potterton combi 80 boiler with digital timer. can someone help and let me know how to use digital timer?
please download the owner manual and read it. go www.retrevo.com or www.manualslib.com or go to the website from the manufcture from digital timer.
God bless you
Oct 28, 2013 | Water Heaters
Neewer eza-c1 manual
EZA-C3 Manual, only difference is the plug that fits the camera...
http://www.scribd.com/doc/100733549/EZa-C3-Digital-Timer-Remote
Jan 30, 2012 | Cameras
How to set timer on potterton boiler
what number do you reccomend on the boiler for the control thermostat to run at.
Feb 18, 2010 | Woods Industries 59377 Indoor Digital...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
