I installed my Printmaster 8.0 on my system that has windows 7 os. It installed, but every time I try to open a graphic it says"Printmaster is shutting down" and does. What can I do?
    Guru:
  • 722 Answers
Uninstall the program, then re-install it. Make sure there are no other programs running that would slow down or affect the installation. Close all web browsers, IM programs, other printer programs etc.
Once you have uninstalled the program, restart the computer, make sure any un-necessary start up programs are not running, then re-install the program.
If this does not fix the issue, I suggest contacting the copyright company (creator of the program) and inquiring with them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on May 26, 2011
  • Brandon Bruce
    Brandon Bruce May 26, 2011
    Also make sure the you have sufficient memory and space that the program requires. You may need to uninstall other programs you don't use often or ever to accommodate for the space, or updgrade your memory.
Trouble installing Printmaster Platinum 16 on Windows Vista
Right click on the installation Icon and choose 'Run as Administrator'
Apr 05, 2012 | Broderbund PrintMaster Platinum 16
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Can't install PrintMaster Platinum 16 on my Windows 7 PC
This version of print master is not compatible with windows 7.
see the compatibility criteria of Printmaster on the link given below!
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=PrintMaster%20Platinum&v=Encore&uid=18&l=en&pf=0&pi=9&c=Graphics%20%26%20Printing&sc=Image%20Editing&os=64-bit
You can try if this works in compatibility mode in your pc - Try running in compatibility mode. Right click the program icon, click Troubleshoot Compatibility, wait while the problem is detected. Click Troubleshoot program > select an appropriate version of Windows the program is known to run in, try Windows Vista SP2 > start the program to see if it runs. If it runs, click next to proceed with saving the settings for it.
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
How do you make Printmaster Platinum 16 work with windows vista
Printmaster Platinum 16 is not compatible with Vista or windows 7. You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
My printmaster 2011 gold won't install. what should I do
Installing printmaster 2011 gold on PC.
System Requirements:
Windows XP (Home & Pro) SP3/Windows Vista SP2/Windows 7*
Pentium IV 1.6 GHz or better (2 GHz recommended) or comparable AMD Processor
1 GB RAM available (2 GB RAM or more recommended, 2 GB required for Windows Vista and Windows 7 users)
Available Hard Disk Space: Installation disc requires approximately 2.7 GB; downloadable content can require up to 36 GB of hard drive space
Internet connection required to access content 16 MB Video RAM (64 MB video RAM recommended)
DVD-ROM drive, keyboard and mouse
Monitor resolution:1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (Available at www.quicktime.com)
Java version 6 or higher required (available at www.java.com)
Recommended Additional Equipment:
Printer, Digital Camera
Macintosh OS X 10.4.8 or greater* (with the latest Java update)
PowerPC G4 500 MHz or faster (G5, PowerPC or Intel Mac--1 GHz processor or better recommended)
Available Hard Disk Space: Install disc requires approximately 3.0 GB; downloadable content can require up to 36 GB of hard drive space
1 GB RAM (2 GB RAM or more recommended)
8 MB Video RAM (64 MB video RAM recommended)
22 GB (hard disc space)
Monitor resolution 1024 x 768 or higher (1152 x 864 or higher recommended)
QuickTime version 7.5.0 or higher is recommended (available at www.quicktime.com)
*Administrator privileges are required to properly install the program on Windows XP, Windows Vista, Windows 7 and Mac OS X
Do your system meets the above requirement?
Nov 15, 2010 | Broderbund PrintMaster Platinum for PC
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
Can I install my software in windows 7
before you can install the windows 7 operating system, download first the windows advisor software that allows you the check your computer if the components of your system is capable for having a windows 7 operating system, it also checks your computer if you have incompatible programs and applications if your thinking of an upgrade from windows vista to windows 7.
if your planning to do an upgrade check the version of your vista OS to see the compatible version of windows 7.
i hope this helps
Feb 25, 2010 | Broderbund PrintMaster Platinum 16
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
(make your program/application run with windows 7)
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
