Question about Canon PIXMA MX860 All-In-One InkJet Printer
Canon pixma MX 860.Its not printing anymore.when it tries it make a loud rattling noice and an error code 5c20 comes up. Cartgridges have been removed and put back.Dont know how to check on the printerhead
    Guru:
  • 352 Answers
Hello.
To check the print head remove the cartridges. To the left of right of the cartridge holder there is a orange or grey lever. lift this and remove the print head. The rattling noise could also be the belt that moved the cartridge carriage back and forward. this belt is directly behind the carriage. This belt may have slipped from its wheels at each end of the printer. look inside it with a torch for a clear view. Before doing this please remove the power cord from the back of the printer to ensure your safety.
I hope this helps Regards GM
Posted on May 26, 2011
Testimonial: "not helpful.please give more detail "
  • Grant Meier May 27, 2011
    The Error code is related to the print head not being in the correct position. the head is moved back and forward by a belt, connected to two wheels as described before.
    If your not confident in looking inside the printer then a service agent will be able to help you.
    I hope you resolve your issue
    Regards
    GM
How do I fix the problem with canon pixma mp 620.error code 5C20 &loud clicking
Solution 1: The logic board is faulty: it can't move the rollers and carriage. Try a reset:
  • On the operator panel, press the button. The display will go blank.
  • Unplug the power cord and plug it back in after 30 seconds to ensure that the device resets itself.
  • Then press the button.
  • Once the printer has restarted, try to print a test page
Solution 2: Pump roller sensor error or Error. The pump roller position cannot be detected.
  • Replace Purge drive system unit
Jul 08, 2012 | Canon Office Equipment & Supplies
Can I fix canon error 5C20 myself?
Dial 18002430019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
May 07, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Code d erreur 5c20....l imprimante ne fonctionne plus
Pump roller sensor error or Error Code 5C20
Condition: The pump roller position cannot be detected.
Problems and Solutions:
visit this link for more info
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 28, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
1p4600 set 5c20 code and makes loud clattering
5C20 says that something is stopping the purge assembly from moving properly like paper scraps or just gummy ink, if there are no scraps on the right where the printhead parks, you probably need to have the purge assembly replaced.
Jan 13, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Canon Pixma MP810 Error messages 6A00, 5110, 5C20, 5100
Pixma pro 9000
service error 5110 after paper jam.
BEST QUICKEST WAY TO FIX THE PROBLEM!!!!
DUST BLOWER ALL OVER THE AREA INSIDE
AND TURN IT BACK ON U SHOULD HAVE SOLID
GREEN LIGHT FOR SURE!!!!!!!!
DAMN I CAN'T BELIEVE I BROUGHT THIS SAME PROBLEM
TO SERVICE CENTER THE FIRST TIME!!!
NO MORE WORRIES!!!
Oct 25, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Canon PIXMA MX860 All-In-One InkJet Printer Logo
2,179 people viewed this question
old marine
old marine
