Question about Hayward H-series Electronic Gas Pool Heater H400
HI WE INSTALL H250FDN POOL HEATER . AFTER A DAY THE HEATER WAS INSTALLED CUSTOMER CALLED MANITOBA HYDRO BECAUSE IT WAS A STRANGE SMELL WHEN THE HEATER BURNING. GAS COMPANY CAME AND SHUT OF THE GAS FROM A REASON THAT IS TO MUCH CO IN FLUE AND NOT ALL THE GAS BURNING. I CAME TO CHECK GAS PRESSURE THAT WAS FINE BY THE MANUAL 7" W C INLET AND 1.84" WC OUTLET FROM GAS VALVE VENTOR MOTOR IS WORKING PROPERLY WHAT CAN BE THE PROBLEM IT IS A BRAND NEW HEATER
    President:
  • Hayward Master
  • 1,378 Answers
The heater literally stinks for some time after it is installed as the fire tile burns in. Every heater we install makes my eyes burn if I get a good whiff of the fumes...Are you certain the utility actually tested the discharge air? My guess would be someone walked up and gave it a sniff and over-reacted to what is a normal odor from a new heater. You can of course double check your flames from below the burner tray. If they are nice bright blue standing 2 - 4 inches tall your heater is operating normally and the smell should subside shortly after it gets some steady use.
John
Posted on May 26, 2011
Why does my hayward h250fd have and if error code? it is a brand new heater
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
There are a few reasons that this might be happening. They range from air in the gas line to inadequate gas flow. Start by checking the installation
Aug 08, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
How do I drain an h250fdn heater
There is a drain plug on the inlet/outlet header.
Oct 23, 2013 | Hayward H Series Electronic Ignition...
When heater is running smell way to much gas
have gas pressure checked if ok check pressure on back side of gas valve also check connections after gas valve
Aug 15, 2013 | Hayward H250FDN Low NOx Natural Gas Pool...
Mastertemp 400 NG heater - unused gas smell when firing
Ask the gas company for the conversion kit part part number they used.
Jul 11, 2017 | Pentair Mastertemp Heater
I want to go over 104 degrees
cannot just can go to calibration and cheat 4 degrees
Jan 12, 2012 | Hayward H250FDN Low NOx Natural Gas Pool...
Header cracked on hayward pool lo nox h250fdn heater. need to replace the header. Please help?!
Headers on hayward heaters are usually warranted for 10 years, except for freeze or chemical damage. You may want to contact a local warranty station to see if you can get it replaced under warranty.
May 07, 2010 | Hayward H250FDN Low NOx Natural Gas Pool...
Heater is new, installed at grade on above ground pool that is 48" deep so pressure switch is 3' below the water line. With pressure switch adjustment turned fully clockwise the heater will run without the...
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
Jul 09, 2009 | Hayward H250FDN Low NOx Natural Gas Pool...
Hayward H-series Electronic Gas Pool Heater H400 Logo
210 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
