Question about Pioneer Televison & Video
My DVD Surround system will no longer read DVD's. You hear it trying to spin making a funny noise then comes up with No Disk
  • 1,800 Answers
The lens is broken change it !!
watch out next time for the dvds that u use if it are clean !!
-----------rate me folow me-------------
Posted on Aug 16, 2008
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
Won't read diisc and makes funny noise
Check first to make sure there are not Two (2) disks in the tray.
The disk may not be seated completely in the tray.
The disk may be upside down.
Try a different disk. If it plays properly, the disk in question is probably bad
Read Ya,
Z
Jan 01, 2010 | Televison & Video
It keeps making funny nosies and won't turn on...
The 'funny' noise would clicking or spinning 'seeking' noises made by your player trying to read its micro Hard Disk in order to start: this is usually indicates that you have a faulty internal disk drive which may have been caused by accidental mis-handling (eg. accidentally dropping or sudden movement while writing to the player).
Dec 24, 2009 | Microsoft Zune JS8-00001 Digital Media...
RCA DRC290 "No Disk"
The noise you hear is an attemp to read the disk, which fails. If you can gain access to the optics assembly, try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, the optics are likely failed and will need to be replaced.
Hope this helps,
Dan
Dec 07, 2009 | RCA DRC290
No Read error even with out a DVD inserted
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Apr 19, 2009 | Panasonic DMRES15 DVD Recorder
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
My ps3 will not read my game nor dvd
Hi my name is Juan and the problem you got is with the bluray laser lens they have stoped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 cliking noises of the laser but make no noise because this cliking noise is so fine that you need to make no noise i goes clik clik clik you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the cliking noise after you have inserd the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happend and the solution is to replace the laser lens I am a ebay thrusted power seller and I can get you one if you want to
Mar 15, 2009 | Sony Playstation 3 (PS3) Console
LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
Does not read the disk
Jan 07, 2008 | JVC RX-DV3SL DVD Player
Televison & Video Logo
47 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
