Question about Ice-O-Matic 150 Lb Ice Machine Under Bar Iceu150fa
IT SEEMS THAT THE ICE IS GETTING STOCK ON THE MACHINE PREVENTING FROM NEW ICE CUBES TO FORM.
    Master:
  • 403 Answers
Most likely , the humidity in the room is to high. Causing freeze points where there should not be.
Posted on May 26, 2011
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
May 15, 2012 | Emerson Im90 Portable Ice Maker
Melting ice
The bin has most likely failed. Apparently the bin insulation on the DCE33 eventually gets saturated with water and loses it's insulation ability. Consequently the ice melts prematurely. Condensation starts to build up inside the bin because it's not cold enough adding to the problem as the water drips on the new ice inside the bin.
Mine is 5-yrs old and I was told that it's all the life I'll get out of it.
If everything else is workng properly, harvest time, cube size, cold water spray, then a new bin is the unfortunate solution.
Apr 02, 2012 | Scotsman DCE33PA1BC 15in Built-in...
I have a ice machine, Hoshizaki IM- 240DME. The machine is making ice with big holes in the middle of the ice cubes. What could be the problem?
These ice machines have "fingers" that the ice is formed around. A defrost cycle melts the ice slightly so that they will slide off into the ice bin. The defrost cycle seems to be on for too long. purchase some ice machine cleaner, follow the instuctions on the bottle and this may solve the problem
Mar 31, 2011 | Refrigerators
I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
Nov 05, 2009 | Scotsman DCE33PA1BC 15in Built-in...
The cubes are hollow and keep get stuck when they try dispence
The cubes are hollow? Means not enough water coming in on the fill cycle to fill the metal ice tray (netal form, see solution #2). There should be an adjustment under the end cover, looks like a screw with a spring around it. Look inside the cover and see if the directions are there for adjusting it properly.
Sep 19, 2009 | Whirlpool GD2SHGX Refrigerator
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Ice-O-Matic 150 Lb Ice Machine Under Bar Iceu150fa Logo
213 people viewed this question
Top Ice-O-Matic Kitchen Appliances - Others Experts
Justin Hall
Justin Hall
Level 1 Expert
Marat Brikov
Are you an Ice-O-Matic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
