Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
P4M800PRO-M V 2.0 NEED MANUAL TO CONNECT FRONT PANEL OF THE CASE POWER, RESET, HD LED ETC....
  • 72 Answers
I have found the manual for your P4M800PRO-M V2.0 Motherboard. The connection diagram is on page 18 of the PDF file or page 12 in the manual. You will find the manual here: http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/P4M8OOPRO-MV2.0.zip or by clicking Here.
Hope this helps. If it does, please accept and rate the solution! You can leave a testimonial or contact me with any more questions you may have. Thanks for using FixYa!
Posted on May 26, 2011
  • Jonathan Herman
    Jonathan Herman Dec 26, 2013
    I need found the enter for the speaker cable. can you help me?
  • Jonathan Herman
    I'm from Brasil, sorry my english
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I am looking for the mother board connection diagram so i can connect the towers front panal ie power switch /reset ect
Connect the front panel leads to the motherboard connector marked "JFP1" using the following pins as indicated by the markings on the motherboard and the front panel leads: HDD LED on Pins 1 and 3; power LED on Pins 2 and 4; reset switch on Pins 5 and 7; and the power switch on Pins 6 and 8.
Good luck.
Mar 03, 2011 | MSI 865GM2-LS Motherboard
How do i wire-up the: ( eg. power l.e.d., HD led, reset led ect. to the board
The various wires from the case front panel should be labeled to indicate power LED, HD LED, etc.
The motherboard front panel jumper pins should be grouped together and the pins should be labeled to indicate PWR, HD. RST etc.
You can go to the motherboard manufacture's WEB site to download a diagram of your model motherboard and it will show all the locations of the connecting pins.
Jan 30, 2011 | Chaintech MP4M266A Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Connetors front panel
you will see underneath the panel pins, where they are supposed to go, there will be +HD Led-, in this case it is positive to the left and negative to the right, work out which wire is your positive, usually red.
When you power up check that the Power Light is on and HDD light is flashing, if they arent take the connector out and turn it around.
If this doesnt work please post you Mobo Serial number here
Dec 18, 2007 | Intel D850MV Motherboard
Reset/power/led etc..lead connections
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
2,147 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
