Question about Whirlpool Refrigerators
I have a Whirlpool Refigerator (double door, freezer over cooler). Its model number is WBM35 IX (made in 2003). Lately I have problems in the fridge. The freezer freezes the items. But there is no cooling in the fridge. Moreover I dont see any cool air being blown either in the freezer or in the cooling compartment. Could it be because of a fan failure?
    Novelist:
    Champion:
  • 222 Answers
My guess is the fan has gone on it. Mine did the same thing. The fridge gets its cold air from the freezer compartment via a fan that is usually in the back of the freezer. It's not a hard replacement, if you're tech-savvy (took me about 1/2 hr.) and the part will cost you about 40 to 70 dollars, depending on where you buy it (priced mine out at $70, I think, but found a local guy who sold me one for $40. It's called an "Evaporator Fan" and I believe this link will show you a possible replacement for it (The crappy part is that you need to take the old one out to look at it to be sure).http://tinyurl.com/3so7a86 Good luck.
Posted on May 26, 2011
  • wasif54 May 26, 2011
    Thanks mate. I will go and find one in the local market here as I live in Dubai and cannot buy online. I will try to replace it by myself.
    Since the fridge is electronic, there has been a continuous beeping; could be because of it. I am just wondering if I can get the manual somehow.
  • James Burton
    James Burton May 26, 2011
    Not sure what to tell you there. I'm just one of them guys who fixes (or breaks) all my own stuff, so I have to figure stuff like that out. I had just bought my fridge for $50 and a week later I had to put the evaporator fan in it. But for $90, I still got a great deal. BTW, I know you said Whirlpool, but the guy told me that the Frigidaire ones like mine go out like once every 3 yrs. and I believe they're all pretty much the same part. Again, good luck my friend; it's bedtime.
WHIRLPOOL WBM35 IX LIGHT NOT WORKING
Check door switch lite will have a switch on door can maybe just a wire off
Jun 29, 2015 | Whirlpool Refrigerators
What are matching models for Whirlpool Oven door model AKZ456/IX
As You may know, Whirlpool also builds Kenmore products, that being said, You would be far better off buying the exact model door for Your oven. The joy You may get from saving a "C" note on an alternative door option could turn into a Personal B*tt Kicking contest when You discover it almost worked, You CAN'T send it back and You still have to buy the right one. Best of Luck to You.
Aug 19, 2014 | Microwave Ovens
Not cooling
Sounds like a defective start relay, run capacitor overload and possibly a defective condenser fan may have started the problem. What is the correct model number found around the fresh food section door?
Sea Breeze
Mar 06, 2013 | GE Profile PDCS1NB Bottom Freezer...
PSG25 side by side GE; Frrezer is perfect but refigerator is goig under temperature set. Technician replaced motherboard and sensors with no luck :-(
HI,
As I am a certified GE technician, I need to ask, has or did the person at your home use a computer on your unit? Reason I ask is that we use a computer to see up has failed in the unit determine what has happen. Either way, I have notice a high call for door switch lately, I would open the refer section and test the door switch, it could be turning your compartment light on with the door closed and cause the same problem even melt butter to a liquid. Other possibility could be that the freezer is frosted, this model does not share air between compartments, and if a sensor failed it can cause this. Yes the unit has 4 sensors and they run about 13-20 dollars.
Each compartment has 2 sensors
I would like to help you further, need complete model number from the unit not the book or the door, its inside unit on a sticker.
I hope this helps
Jul 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer section is not cold enough and the fridge section is totally warm. my fridge model is WBM35 IX. called the technician (not from whirlpool though because the agent is no longer available in...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 03, 2011 | Whirlpool Refrigerators
The freezer section of my whirlpool double door refrigerator becomes too cool while refrigerator section does not cool lower than 56 deg F. Setting of Freezer section is at minimum cool (extreme left)...
when you open the freezer door you should hear a fan running, that's what cools your refrigerator section. If you don't hear that fan, that may be the problem. Also if there is frost on the back panel of the freezer that also may indicate a defrost problem, which could cause the same problems
Aug 22, 2010 | Refrigerators
TRAULSEN RDT232 REFIGERATOR/FREEZER. TRIPS CIRCUIT
Since you are convinced that the circuit is sufficient, look for a voltage drop during start up. In the unique case, when both units try to start at the same time, a voltage drop can cause overamping and trip the breaker.
Look at that and let me know if we need to go any farther
Jun 06, 2010 | Traulsen Commercial 2 Door Cooler /...
Sub-Zero model 550 does not cool properly
make sure the coils are clean first both coils, then check the r22 freon
Jul 21, 2009 | Freezers
Refrigerators Logo
235 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
