Question about Aastra Telecom Aastra M6320 Single Line Corded Telephone (AASTRAM6320)
I have just been assigned a Telstra M6320 spectrum phone, and my existing Plantronics headset which is called Duoset P141-U10P (on the outside of my old box) does not work. I have 2 different cords that connect the headset to the phone (don't know what type) but neither of those work. What do I order to make my headset work?
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
This headset is a combination of Polaris components and is no longer available. What you will need is a Plantronics H41 and a Plantronics M22 amplifier.
Good luck from Headsets Direct!
Posted on Sep 06, 2011
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
Mar 09, 2015 | Mitel 5330e IP Phone 50006476
Binatone Acura 3000 Corded Phone with Answer Machine
Sadly you are trying to do something that the phone is not capable of doing .
Sep 12, 2017 | Plantronics Audio Players & Recorders
How do you change pre-assigned Feature Keys 2 - 13 ?
This can usually be done via your phone system. However you can program each phone independently by IP'g into each phone.
Hope this helps!
Jun 07, 2017 | Aastra Telecom Meridian 6320 Corded Phone...
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Nov 07, 2011 | Plantronics S11 Headset
How to make a call
The first step after charging is to pair the headset to the cell phone, you may also have to turn the Bluetooth or headset function "on" in the menu of the cell phone (depending on the individual phone). Here is a link for the Plantronics 200 series user guide, this will walk you through the pairing and calling process.
Plantronics 200 Series User's Guide
Sep 16, 2011 | Plantronics Explorer 240 Bluetooth Headset
Even though the volume is turned all the way up on both my cell phone and on my plantronics 220,both fully charged,I can barely hear any type of call. whether its a given or recieved call.
Try to delete the bluetooth from the phone, and re-pair it or subscribe back on the phone. It may be that your headset is old and needs to be replaced. If this does not work look at the Plantronics M100 bluetooth headset.
I have included the users guide for the Plantronics Explorer 220 headset.
Jul 18, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Plantronics HL10 Handset Lifter
Good Luck from Headsets Direct!
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
Hi, At the office we have a Mitel IP phone we have just bought a headset model JAC0021201- B. We cant get it to work. Please can you advise how we set this up. Regards Trevor
I'm not finding manufacturer detail on this headset, only sales via Amazon, and it's dicey info at that.
So,I'm not certain this headset is compatible.  The only Mitel approved headsets are the Plantronics Polaris models.  These headsets fit into the headset port.  Such headsets require a headset button to be programmed and enabled on the phone to work.  When the phone rings, you will have to press the ringing button, to hang up, you will have to press the cancel button.
Other headset models may work, but require them to be plugged into the handset port and the existing handset will have to be plugged into it's unit.  Such units will require lifting the handset to answer the call and hang it up when completed.  Some such units have an optional lift kit.
I personally use a Plantronics Polaris "in the ear" model.  Plantronics web site has a config guide that will help you select a headset.
http://www.plantronics.com/us/configurator/default.jsp?use=Deskphone
good luck,
Mark
Mar 16, 2011 | Mitel 5220 IP Phone
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Bluetooth is paired and on but instead of answering calls, send call straight to voicemail.
    Is there a visble window setting You may have to change it to be visible to your phone for more than a few minutes. Check your setting on answering or sending all incoming to the answer machine. Press the large face button to answer a call.
    http://safemanuals.com/user-guide-instructions-owner-manual/PLANTRONICS/EXPLORER%20220-_E link to playtronics for user manual.
    Apr 15, 2009 | Plantronics - Bluetooth Headset Plus Base...
    Aastra Telecom Aastra M6320 Single Line Corded Telephone (AASTRAM6320) Logo
    300 people viewed this question
    Top Aastra Telecom Lands Phones Experts
    Illimar Saatvali
    Illimar Saatvali
    Jose Ma DM.
    Jose Ma DM.
    Michel Laprise Sr
    Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
